M59 Backhoe Thumb Aux Hydraulics
   / M59 Backhoe Thumb Aux Hydraulics #1
mikester
Elite Member
Canada
M59 TLB
Has anyone here looked at swapping/modifying the aux. manual hydraulic control valve to electric solenoid operation to replace the foot lever?
And before I start opening things up does anyone know what kind of valve body Kubota uses if I can match up to an aftermarket valve?
   / M59 Backhoe Thumb Aux Hydraulics #2
Glad you posted this as I have wondered about that myself. The foot actuated valve is kinda awkward for me, and I can't use it from the seat facing forward like the other sticks. I find that I often lower the boom or swing it from side to side while Im moving forward to get under a lean-to roof or want to put a side angle on my loader blade.
Same complaint here, it’s hard to actuate the pedal wearing steel toe boots. I want to put a toggle switch on the bucket control. Ideally I want to find some kind of electro-mechanical actuator kit I could simply bolt on to the existing valve body to replace the foot lever. I see a lot of pneumatic actuator kits for trucks but adding a compressor seems a little too costly.
   / M59 Backhoe Thumb Aux Hydraulics #4
Surpluscenter.com have 12v linear drives for experiments. They also have 12v hydraulic valves.
A simpler idea might be a hand lever near the backhoe hand controls mechanically linked or replace the OEM foot control.
Folks using their backhoe with an auger might like the option too.
I have a B26 with thumb that makes the foot deck very cramped with my big brogans.
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2006 Husqvarna YTH2148B 48in Riding Mower (A51694)
2006 Husqvarna...
2025 New/Unused Wolverine 3 Point Quick Hitch (A51573)
2025 New/Unused...
2021 VOLVO A40G (A52472)
2021 VOLVO A40G...
2015 KUBOTA M9960 LOT NUMBER 214 (A53084)
2015 KUBOTA M9960...
RHINO DB150 LOT NUMBER 76 (A53084)
RHINO DB150 LOT...
