5030
Rest in Peace
- Joined
- Feb 21, 2003
- Messages
- 28,967
- Location
- SE Michigan in the middle of nowhere
- Tractor
- Kubota M9000 HDCC3 M9000 HDC
The inherent issue with any EGR system (especially on a diesel engine) not so much on a gas engine is..
When you put exhaust gas from a diesel into the intake runner of a diesel engine, it crystalizes and attaches itself to the intake runner' walls and in the intake ports and the backside of the valves themselves and forms a hard coating that resembles black icecream that has frosted from age.
Detroit Diesel (DDEC) found that out the hard and costly way as they had to replace and rebuild countless engines and replace clogged intake runners, because the emissions sensors in the runners failed because of the carbon buildup and caused the engines to self destruct.
Gas engines will 'coke' up as well if they are GDI engines with no pilot jets in the intakes to keep the intake tract misted with gasoline.
Interestingly, I can hear the turbo's on both my M9's spool up and it's always a sweet sound, but then I'm not wastegated at all either. Only thing my engines have is a 'puff limiter' similar to what Vo Mack used and mine is defeated by my own hand. Whatever the hairdryer can make, it's all going through the air to air unit and into the intake runner. In fact, if you throttle up either of mine with the hoods open and observe the intake piping from the ATA unit back, as you throttle the engine up, you can observe the rubber intake runners expanding from the boost pressure.
If you ever have the chance to pop the hood on a Mack, take a look at the turbo housing. Plainly cast into the housing are the words 'This is a muffling device'. ...and it is. The turbo breaks up the sound waves from combustion, they all do but Mack states it right on the outer housing.
