m5040
/ m5040 #1
Tdcw4
Recently purchased a m5040 and was wondering should a light come on when u put it in 4wd and also when u put the headlights on bright? I checked the fuses and they are all good. Anyone have any ideas or a tractor like this that might give me a heads up?
/ m5040 #2
I have a M5040 and the dash indicator lights you mentioned don't work either. It came from the factory that way.
/ m5040 #4
They light up on our M8540, but I am not sure about the M5040; would assume they are the same though.
/ m5040 #5
I just purchased a new m5040 1 month ago and a green tractor emblem lights up when I engage 4X4.
/ m5040 #6
My 7040 has the green light that lights up when the front drive is engaged.
I remember reading about some issues with early ones that had some of the wires under the dash with bad or missing connections.
/ m5040
Does anyone know which wires are supposed to be hooked up or what connections may need to be looked at
/ m5040 #8
/ m5040 #9
ditto on the 4wd light. I don't think mine has a high beam indicator. But if you need the light, you can usually tell easily if it's high or low.
/ m5040
Does anyone know what wires to check?
8ft. x 4ft. Lighted Sign (A65640)
8ft. x 4ft...
12ft. Field Cultivator (A65640)
12ft. Field...
Metal Donkey (A65583)
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
58in Wagon Wheel Bench (A65583)
58in Wagon Wheel...
