M4700 starter question
/ M4700 starter question #1
finspop
Hello,
I have a new-to-me M4700 with 900 hours. I frequently get a grinding noise when I go to start it, as if the starter has not fully disengaged. Of course, I always turn the key off immediately and on the next try, it generally starts as normal.
Does this sound like a starter issue, or solenoid, or??
Thanks in advance for any advice.
/ M4700 starter question #2
Hello,
I haven't ever had that on my tractor, but have on cars. The bendix is weak. It needs to snap the gear over faster. Could be gummed up or just worn out. The result is what you have. It will wear the starter gear down and cause it to grind even more next time. You might be able to lube it to help out but you may want to just replace it. Don't know if you could just buy parts or need to replace the whole starter. But you need to do something soon before the wear starts to get the ring gear or you'll really be spending money to tear things apart.
(10 Bundles) Standing Seam Metal Roofing (A61166)
(10 Bundles)...
30 Yard Roll Off Dumpster (A61165)
30 Yard Roll Off...
UNUSED RAYTREE AMBD72S-72" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
2007 John Deere 644J Articulated Wheel Loader (A59228)
2007 John Deere...
1997 International 4700 Bucket/Chip Truck, VIN # 1HTSCAAP2VH489823 (A61165)
1997 International...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
