M105X Thoughts & questions
   / M105X Thoughts & questions
Would you share with me how you went about installing the buzzer on the parking brake. Where you bought the alarm, where you mounted and hooked the wires up to. While you are at it it would be nice to have a horn I might do that also if I could make it look nice.
Tom
   / M105X Thoughts & questions #12
Hope i can remember!I bought 2- 12VDC chimes from Radio Shack $10 each,used switch to (supply negative to chimes) under brake lever, got postives from lights forward and reverse on console.Works great only have alarm when in forward or reverse and brake is on.I was actually sort of proud of myself for figuring it out.That loader has such a front reach i located my 15gal.foam marker in between front of tractor and loader.
20FT X 12FT LIVESTOCK SHELTER (A58214)
20FT X 12FT...
2002 International 9200i Truck (A56438)
2002 International...
2844 (A58376)
2844 (A58376)
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
2020 Deere 50G (A53317)
2020 Deere 50G...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
