m/f 1260 advise
   / m/f 1260 advise #1
sl95311
massey ferguson 1260
my M/F 1260 idles fine but when put into gear it dies.any advise to my problem?
   / m/f 1260 advise #2
We could probably troubleshoot your problem better with a little more info.. Will the tractor engine rev up beyond idle when you increase throttle (in neutral)? Does it immediately die when the tractor is in gear and you let the clutch out? Has the tractor been running normally, or have you been noticing an oncoming problem?
   / m/f 1260 advise
yes it does rev up in idle when throttle is increased in neutral, and it does immediately die when the tractor is in gear and you let out the clutch. have not noticed any problems up to this point. thank you
   / m/f 1260 advise #4
My first check would be the operator presence switch, (seat switch), Lift up the seat and make sure the wires running to the switch are in good condition, no breaks bad spots etc.., If they are in good shape unplug the switch and run a jumper wire across the terminals (tractor side of plug, not seat) then start it up and put in gear and see what happens.
2020 RoGator RG1300C Spreader (A53342)
2020 RoGator...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
2023 CIMC 53X102 REEFER TRAILER (A52576)
2023 CIMC 53X102...
2024 Kubota RTV-X (A51573)
2024 Kubota RTV-X...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
