m/f 1260 advise
   / m/f 1260 advise #1
sl95311
massey ferguson 1260
my M/F 1260 idles fine but when put into gear it dies.any advise to my problem?
   / m/f 1260 advise #2
We could probably troubleshoot your problem better with a little more info.. Will the tractor engine rev up beyond idle when you increase throttle (in neutral)? Does it immediately die when the tractor is in gear and you let the clutch out? Has the tractor been running normally, or have you been noticing an oncoming problem?
   / m/f 1260 advise
yes it does rev up in idle when throttle is increased in neutral, and it does immediately die when the tractor is in gear and you let out the clutch. have not noticed any problems up to this point. thank you
   / m/f 1260 advise #4
My first check would be the operator presence switch, (seat switch), Lift up the seat and make sure the wires running to the switch are in good condition, no breaks bad spots etc.., If they are in good shape unplug the switch and run a jumper wire across the terminals (tractor side of plug, not seat) then start it up and put in gear and see what happens.
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
JOHN DEERE 460M LOT NUMBER 258 (A53084)
JOHN DEERE 460M...
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A51694)
2009 Skeeter SL190...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
JOHN DEERE R4023 LOT NUMBER 261 (A53084)
JOHN DEERE R4023...
2025 New/Unused Wolverine 72'' Skid Steer Ripper (A51573)
2025 New/Unused...
