m/f 1260 advise
   / m/f 1260 advise #1
sl95311
massey ferguson 1260
my M/F 1260 idles fine but when put into gear it dies.any advise to my problem?
   / m/f 1260 advise #2
We could probably troubleshoot your problem better with a little more info.. Will the tractor engine rev up beyond idle when you increase throttle (in neutral)? Does it immediately die when the tractor is in gear and you let the clutch out? Has the tractor been running normally, or have you been noticing an oncoming problem?
   / m/f 1260 advise
yes it does rev up in idle when throttle is increased in neutral, and it does immediately die when the tractor is in gear and you let out the clutch. have not noticed any problems up to this point. thank you
   / m/f 1260 advise #4
My first check would be the operator presence switch, (seat switch), Lift up the seat and make sure the wires running to the switch are in good condition, no breaks bad spots etc.., If they are in good shape unplug the switch and run a jumper wire across the terminals (tractor side of plug, not seat) then start it up and put in gear and see what happens.
Electric Mobility Scooter (A51694)
Electric Mobility...
JOHN DEERE 7210R LOT NUMBER 262 (A53084)
JOHN DEERE 7210R...
24'' Mini Excavator Bucket (A51573)
24'' Mini...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A53472)
2018 John Deere...
T3 Motion Patroller Segway (A51694)
T3 Motion...
