Lynch Pins Coming Off
   / Lynch Pins Coming Off #111
I've experienced the same thing. Seems like it's always doing pretty rough brush-hogging, nothing else. Zip ties and or mechanic's wife both are satisfactory fixes. I'm not patient enough to use bolts and lock nuts, though it's probably the absolute best fix.
I’m definitely trying several of these ideas and go through a process of elimination thing. Bolts and nuts on the front of lift arms because they won’t need removing and that’s one spot the lynch pin disappeared. Safety wire on some, etc…
   / Lynch Pins Coming Off #114
There are several posts about this but not many recently so a new day means new ideas. When I brush hog a different lynch pin falls off nearly every time. I've brush hogged five times in the last two months and have lost four lynch pins.
Facts: I do have a lot of overgrown weeds and saplings and I do use the HD black lynch pins.
My question is how do I keep them from coming off? I don't care about losing them so much as I do about tearing up my equipment. Chaining them to somewhere on the tractor just keeps me from losing the pin but it doesn't stop the inevitable damage from the pin coming out. Is there a better more secure pin out there other than a bolt and nut? Duct tape? Key rings? Thanks in advance for any and all suggestions.
Fixit 1
I use flat washers on mine between the arm or link & the lock pin. I have noticed the arm or link works the lock pin out of the hole in the pin. It works for me, also a little squirt of Fluid Film on the pins seems to help. Cheers!!
   / Lynch Pins Coming Off #115
I only lose them where the lift arms attach to the tractor and only when I use my neighbors heavy duty 5ft brush hog, so I went with bolt and lock nut that someone else mentioned in another post. I tried the black pins from tsc but they came off too.
   / Lynch Pins Coming Off #116
Picture is worth a thousand words! Please send👍🏻👍🏻👍🏻
You will win the comment of the day!🚜✌🏻
Before applying the springs the pins would rotate on their axis which made it very easy for them to come off now they have tension and stay flat or horizontal and have never lost another pin sence, hope this makes sense.
   / Lynch Pins Coming Off #118
For the pins that are not removed often, just put in a 1/4" bolt with a lock nut in place of the lynch pins.
Having a quick hitch like the iMatch facilitates this switch to bolts, as well as those lynch pins used to secure the arms to the tractor pivot pins.
I lost one once, and almost cost me a broken casting.
   / Lynch Pins Coming Off #119
Some questions about how these come out. I've lost several over the years and believe one way is branches are springing up and grabbing the ring, just guessing but tree limbs have created havoc for me in several different ways. Some are stiff as metal and some are springy and seem unbreakable and can slip in almost any where and grab and puncture and pull "stuff". My 2 cents.
I keep planning on getting some hardened steel bolts with nuts the right size and bolting some of my attaching points down or in.
Fixit 1
That’s a great idea, thank you!
Honda EG 4000CL Generator (A55973)
Honda EG 4000CL...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2017 Ford F-350 Ext. Cab Pickup Truck (A56858)
2017 Ford F-350...
Pull Type Concrete Mixer (A57453)
Pull Type Concrete...
2017 Ford F-350 Flatbed Service Truck (A56858)
2017 Ford F-350...
