LX6 vs. MX6
/ LX6 vs. MX6 #81
Hi Bob,
The blades work the same as most any cutter I've seen: heavy steel object swinging on a pivot point (bolt)... irresistable force meets shreddable object.
Only difference is MX's (& woods brushbulls) tend to have a higher blade tip speed at PTO speed than many others, resulting in somewhat better cut & higher real-world cutting capacity.
Also Deere uses lift type blades that have a trailing edge that angles up (like aileron when plane climbs) to produce lift for lighter objects & grasses/brush to be drawn up into the cutter.
For blade maintenance, make sure bolts are torqued down to the point it feels your elbow might explode, then go a little tighter ( if you have impact wrench 450 ft lbs I think)
Be sure blades swing freely from the stump jumper.
Edge is ground with bench or angle (my preference) grinder once it gets too beat up (NOT intended to be sharp edge--look at them while they're new... thats the design)
They are not high maintenance machines--good gear oil/level, grease shaft & tail wheel regular, check blade & gearbox torque, & the above for blades.
Very important: make sure that slip clutch slips when necessary--they do bind up if left idle... search here will give some tricks.
/ LX6 vs. MX6
Thanks for the feedback. It sounds like they are less maintenance than my finish mower (Buehler FarmKing).
Since I'm not getting the unit for another week, any thoughts on how to best go about cutting 2-3ft hay grass and swamp grass with it? Any rules of thumb on use I should keep in mind?
Thanks!
-Bob
/ LX6 vs. MX6
Thanks!
-Bob
/ LX6 vs. MX6 #84
Take off the chains and pto shield. They just get in the way...
Cut the skirts off, They just get in the way...
Inject propane in the fuel system...
Hey, what kinda advice do you expect from a guy who jumps hay bales?!!
/ LX6 vs. MX6 #85
/ LX6 vs. MX6
I'm surprised you didn't suggest Nitrous with a hemi-adjustment! /forums/images/graemlins/grin.gif
But seriously - can this thing just wade into that kind of grass and take it all apart? /forums/images/graemlins/ooo.gif
-Bob
/ LX6 vs. MX6
-Bob
/ LX6 vs. MX6 #88
Propane IS nitrous - its a diesel!
No problem! Take partial bits at first to get the feel, but it should really whack that stuff without flinching...
/ LX6 vs. MX6 #89
/ LX6 vs. MX6
Wow... I can't wait to see what it will do to that thick grass...
/forums/images/graemlins/cool.gif
-Bob
/ LX6 vs. MX6
-Bob
/ LX6 vs. MX6 #92
The first time I used my MX6 was to go thru 2 year old growth in fields. Took it with no problem. However, after getting off of the tractor, my ears where ringing for hours. Now I use hearing protection when using the MX6.
Dust can be bad too, some rain a day or two before you mow helps.
Joe
/ LX6 vs. MX6 #93
Joe
/ LX6 vs. MX6
I usually use noise-dampening ear phones with my iPod when I'm cutting grass... I'll definately make sure I have it the same way when I take out the MX6 the first time!
I can't wait to see how it handles itself! /forums/images/graemlins/cool.gif
-Bob
/ LX6 vs. MX6
-Bob
HOSE REELS (A68842)
HOSE REELS (A68842)
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2019 FREIGHTLINER...
2016 Ford Escape SUV (A66738)
2016 Ford Escape...
2016 KEYSTONE 5th WHEEL (A67714)
2016 KEYSTONE 5th...
2022 CHEVROLET TAHOE (A66091)
2022 CHEVROLET...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
