LX490- Where is transmission/hydraulic oil sump breather
   / LX490- Where is transmission/hydraulic oil sump breather #1
Raised on a Deere
Lawrenceburg Ky
Ford Dexta, Branson 6530c Yanmar Lx490 Power reverser
Tractor is Yanmar LX490 2013 year. Need to rule out pressure build up in the transmission/hydraulic sump. There has to be a breather or venting somewhere but I don't see it. Probably similar to LX450 and some others.
   / LX490- Where is transmission/hydraulic oil sump breather #2
The breather pipe for transmission housing is on top of the rock shaft housing it is a 90 degree pipe
Thanks, feel a little silly for asking but got in overwhelm mode over what is going on with my hydraulic fluid in the crank case problem. So need to check the vent.
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A52748)
Ditch Witch 6510A...
BUYER'S PREMIUM INFO (A53084)
BUYER'S PREMIUM...
2023 Yamaha YXZ 100R SS (A51573)
2023 Yamaha YXZ...
500BBL WHEELED FRAC TANK (A52472)
500BBL WHEELED...
