LX490- Where is transmission/hydraulic oil sump breather
   / LX490- Where is transmission/hydraulic oil sump breather #1
Raised on a Deere
Lawrenceburg Ky
Ford Dexta, Branson 6530c Yanmar Lx490 Power reverser
Tractor is Yanmar LX490 2013 year. Need to rule out pressure build up in the transmission/hydraulic sump. There has to be a breather or venting somewhere but I don't see it. Probably similar to LX450 and some others.
   / LX490- Where is transmission/hydraulic oil sump breather #2
The breather pipe for transmission housing is on top of the rock shaft housing it is a 90 degree pipe
Thanks, feel a little silly for asking but got in overwhelm mode over what is going on with my hydraulic fluid in the crank case problem. So need to check the vent.
2007 Ford Taurus Passenger Car (A51694)
2007 Ford Taurus...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52748)
Kubota 24in Quick...
Walk-Behind Automatic Seed Spreader (A51691)
Walk-Behind...
2008 JACK COUNTY  130BBL VACUUM TRAILER (A52472)
2008 JACK COUNTY...
