LX410 three point hitch control
   / LX410 three point hitch control #1
NHSawyer
Southern NH
Cub Cadet/Yanmar LX410
Hay Folks,
The 3 point hitch lever on my LX410 has always been a bit of problem. When the hitch arms are down and I want to lift it I have to move the lever to about the 5.5 position before it even begins to lift. Does anyone else have this problem?
It would be better if it started to lift somewhat before you use nearly all the movement available in the lever.
Just kind of wondering if anyone else has bumped into this.
NH
   / LX410 three point hitch control #2
I think that's normal. Moving the lever to the top will close a valve, which diverts hydraulic fluid and fills the lift cylinder. You get your height control by lowering the lever, which bleeds out fluid to the height you want. You should get a full lowering range of motion, with the link arms near the ground at the lowest point. You can also tweak the height a little with the pins on the low end of the lift arms.
Katahdin thanks
2015 Chevrolet Silverado 2500HD (A52748)
2015 Chevrolet...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A52748)
2024 BCL...
2013 Chevrolet Equinox LTZ AWD SUV (A50324)
2013 Chevrolet...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A52576)
2018 INTERNATIONAL...
PRESSURE WASHER GAS (A52472)
PRESSURE WASHER...
2012 Ford Edge SUV (A50324)
2012 Ford Edge SUV...
