LX410 three point hitch control
   / LX410 three point hitch control #1
NHSawyer
Bronze Member
Southern NH
Cub Cadet/Yanmar LX410
Hay Folks,
The 3 point hitch lever on my LX410 has always been a bit of problem. When the hitch arms are down and I want to lift it I have to move the lever to about the 5.5 position before it even begins to lift. Does anyone else have this problem?
It would be better if it started to lift somewhat before you use nearly all the movement available in the lever.
Just kind of wondering if anyone else has bumped into this.
NH
   / LX410 three point hitch control #2
I think that's normal. Moving the lever to the top will close a valve, which diverts hydraulic fluid and fills the lift cylinder. You get your height control by lowering the lever, which bleeds out fluid to the height you want. You should get a full lowering range of motion, with the link arms near the ground at the lowest point. You can also tweak the height a little with the pins on the low end of the lift arms.
Katahdin thanks
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A51694)
2009 Skeeter SL190...
2015 INTERNATIONAL PROSTAR TANDEM AXLE MID ROOF SLEEPER (A52577)
2015 INTERNATIONAL...
2005 Hummer H2 4WD SUV (A50324)
2005 Hummer H2 4WD...
FAKE (A52472)
FAKE (A52472)
2017 Ford Expedition EL Multipurpose Vehicle (MPV) (A51694)
2017 Ford...
2012 JOHN DEERE 410K BACKHOE (A51246)
2012 JOHN DEERE...
