LX280 failed PTO
/ LX280 failed PTO #11
I had a similar problem with a Cub Cadet. I had 12V going to the PTO clutch when the switch was activated but it wouldn't engage. There is only 2 wires, one hot from the switch and 1 ground. Turns out it had no ground. I used a jumper wire with alligator clips to test and the clutch engaged fine. The ground side is usually tied in through some safety switch which was open, not allowing the ground side to make connection. I couldn't locate the bad safety switch so hard wired a new ground wire bypassing the safety switch.
/ LX280 failed PTO #12
My wife had the same problem on our Deere lawn tractor. I turned the ignition switch to the next position and that made the clutch work.
Eric
2008 CATERPILLAR 420E BACKHOE (A59823)
2008 CATERPILLAR...
Deere 333E (A60462)
Deere 333E (A60462)
John Deere 5090GN (A60462)
John Deere 5090GN...
CAT FORKS W/ QUICK CUPPLER ATTACHMENT (A60736)
CAT FORKS W/ QUICK...
2020 MACK GRANITE (A60736)
2020 MACK GRANITE...
Deere 331G (A53317)
Deere 331G (A53317)
