LX279 Lawn Mower-Transmission Oil? / Tire Slime ?
   / LX279 Lawn Mower-Transmission Oil? / Tire Slime ? #1
Anonymous Poster
Epic Contributor
I dropped my rider in for service this morning, had it now 5 years. Had some leaky tires from a thorn or something so I'm having them place tubes in all 4 tires and they I told them to add that slime inside the tubes. Anyone have any issues with this? I didn't want that slime on the rims, so I told them to add the tubes.
For the hydro trans question,
At 4 years I drained the oil from removing a few bolts on the bottom the trans, dealer said to replace it with 10w-30 motor oil (that was 2 verified calls to two dealers). Theres no spin on filter, theres just a metal screen in the tranny according to the JD website manual so I didn't replace the screen, cause I would had to drop the tranny bottom plate.
So I replaced the oil with 10w30, I ran it all last summer, it seemed to run fine, and no louder noise or such. This winter while sitting it started to drip leak. And continues to leak some.
Thinking that this isn't right, I decided to send it in to the dealer and let -them- service the transmission (oil, screen filter cleaning), find the leak, replace belt trans drive etc..
When I went in this morning and asked them what weight fluid oil they were gonna use, they said Low Viscosity JD Hydro. I said you guys told me 10w30 last year??? He said, no we should have never said that.
Needless to say I was a little miffed by them telling me different answer now, my question is -
Did I hurt my hydro transmission running 10w30 motor oil for one summer?
Thanks,
John
   / LX279 Lawn Mower-Transmission Oil? / Tire Slime ? #3
I had this mower and I used 10w-30. It said it right in the manual that I had. I never had any problem at all with my hydro.
   / LX279 Lawn Mower-Transmission Oil? / Tire Slime ? #4
Solution Number: 48309
Doc ID: MX48309
Solution Summary: SIB 03-11-25-1 Oil For Use in Automatic Transmissions - LX200 Series
Publication Date: Jan 7 2003
03-11-25-1 (Linked to Pathways) (This SIB updates SIB 00-11-25-24 dated 22 September 2000)
7 January 2003
DTAC Solution: 48309
OIL FOR USE IN AUTOMATIC TRANSMISSIONS
LX200 Series Lawn Tractors
Complaint or Symptom:
Oil listed in Operator’s Manuals and Technical Manuals for transmissions is inconsistent. Depending on the manual, 5W30 synthetic, 10W30 synthetic or 10W30 engine oil is recommended. Which is correct?
Oil is not available as a John Deere part number.
Situation:
Operator’s Manuals and Technical Manuals are confusing.
Solution:
Use the following chart to determine correct oils to be used.
Product
Notes
Oil
Additional Information
LX255, LX266, LX277, LX277AWS, LX279 and LX288
K62 Serviceable transmission with oil reservoir
Turf-Gard 10W30, Torq-Gard Supreme 5W30 or Hy-Gard Transmission Oil J20C
For top-off or complete transmission refill.
Additional Information:
Operator’s Manuals will be updated during next scheduled revision.
LX279, LX277, LX255, LX288, LX277AWS
2017 FREIGHTLINER CASCADIA TANDEM SLEEPER (A52576)
2017 FREIGHTLINER...
Landoll Hauloll (A53472)
Landoll Hauloll...
CASE 580 SUPER N BACKHOE (A51246)
CASE 580 SUPER N...
2020 CASE IH 110N LOT NUMBER 222 (A53084)
2020 CASE IH 110N...
JCB 409 AGT4 WHEEL LOADER (A51246)
JCB 409 AGT4 WHEEL...
2017 Rogator RG1300B Dry Fertilizer Applicator (A53472)
2017 Rogator...
