Lx178 won’t start
   / Lx178 won’t start #1
Stonecold666
Lx178 and 770
Have a lx 178 that has not started correctly for the past year. 12 volts to starter. Replaced starter and solenoid with spare one. Tried new battery. If tap starter a bunch of time it will start and run fine. Cleaned all connectors. Here click at relay but starter doesn’t spin or engage. Any thoughts thank you
   / Lx178 won’t start #2
If you tap the starter a bunch of times and it starts, did the old starter act the same way or have you replaced one problem with another? You could take both starters to a shop which specializes in starter repair and have them checked.
   / Lx178 won’t start #3
Have you checked all of the related stupid safety switches?
   / Lx178 won’t start #4
Usually that is the solenoid, but have you checked for voltage drop to the starter on both the trigger and main lug?
   / Lx178 won’t start #5
Re: Lx178 won稚 start
Stonecold,
Welcome to TBN
:welcome:
Richard
   / Lx178 won’t start
So it turns out to be a bad relay. Had a 4 prong from another mower and started right up with jumper pack and battery charge. New relay on the way. Thank You
   / Lx178 won’t start #7
:thumbsup:
WEATHERFORD MP-10 TRIPLEX MUD PUMP POWERED BY A CATERPILLAR 3412 ENGINE (A50854)
WEATHERFORD MP-10...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
Tandem Axle Rear Truck Frame (A48081)
Tandem Axle Rear...
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
Komatsu PC490LC-11 Hydraulic Excavator (A49346)
Komatsu PC490LC-11...
