Lx178 won’t start
   / Lx178 won’t start #1
Stonecold666
Lx178 and 770
Have a lx 178 that has not started correctly for the past year. 12 volts to starter. Replaced starter and solenoid with spare one. Tried new battery. If tap starter a bunch of time it will start and run fine. Cleaned all connectors. Here click at relay but starter doesn’t spin or engage. Any thoughts thank you
   / Lx178 won’t start #2
If you tap the starter a bunch of times and it starts, did the old starter act the same way or have you replaced one problem with another? You could take both starters to a shop which specializes in starter repair and have them checked.
   / Lx178 won’t start #3
Have you checked all of the related stupid safety switches?
   / Lx178 won’t start #4
Usually that is the solenoid, but have you checked for voltage drop to the starter on both the trigger and main lug?
   / Lx178 won’t start #5
Re: Lx178 won稚 start
Stonecold,
Welcome to TBN
:welcome:
Richard
   / Lx178 won’t start
So it turns out to be a bad relay. Had a 4 prong from another mower and started right up with jumper pack and battery charge. New relay on the way. Thank You
   / Lx178 won’t start #7
:thumbsup:
2006 STERLING TANDEM AXLE FLAT BED (A50505)
2006 STERLING...
2017 Ford F-250 Knapheide Service Truck (A48081)
2017 Ford F-250...
2003 GMC C7500 16ft Cab and Chassis Truck (A48081)
2003 GMC C7500...
1993 Harsh Feed Mixer (A50397)
1993 Harsh Feed...
1262 (A50490)
1262 (A50490)
2012 Ford E-350 Super Duty Passenger Van (A48081)
2012 Ford E-350...
