Lx178 won’t start
   / Lx178 won’t start #1
Stonecold666
Lx178 and 770
Have a lx 178 that has not started correctly for the past year. 12 volts to starter. Replaced starter and solenoid with spare one. Tried new battery. If tap starter a bunch of time it will start and run fine. Cleaned all connectors. Here click at relay but starter doesn’t spin or engage. Any thoughts thank you
   / Lx178 won’t start #2
If you tap the starter a bunch of times and it starts, did the old starter act the same way or have you replaced one problem with another? You could take both starters to a shop which specializes in starter repair and have them checked.
   / Lx178 won’t start #3
Have you checked all of the related stupid safety switches?
   / Lx178 won’t start #4
Usually that is the solenoid, but have you checked for voltage drop to the starter on both the trigger and main lug?
   / Lx178 won’t start #5
Re: Lx178 won稚 start
Stonecold,
Welcome to TBN
:welcome:
Richard
   / Lx178 won’t start
So it turns out to be a bad relay. Had a 4 prong from another mower and started right up with jumper pack and battery charge. New relay on the way. Thank You
   / Lx178 won’t start #7
:thumbsup:
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A50505)
2018 INTERNATIONAL...
2025 76in Dual Cylinder Grapple Rake Skid Steer Attachment (A49346)
2025 76in Dual...
2013 John Deere 640FD Flex Draper Head (A50657)
2013 John Deere...
2021 Doyle 8 Ton Trailer Tender (A50397)
2021 Doyle 8 Ton...
CATALOG IS A GUIDE ONLY!! (A50774)
CATALOG IS A GUIDE...
LOOK! (A50657)
LOOK! (A50657)
