LX178 Throttle Control
/ LX178 Throttle Control #1
khodgens
PAGOSA SPRINGS
LX178
I have a 1998 LX178 and have just overhauled the carb. My throttle lever on the dash has always only gone forward halfway. It seems to me that's the fast idle location. Should the lever go forward all the way for chocking? If so I need to go thru the manual and adjust everything from scratch. Any guidance would be appreciated.
/ LX178 Throttle Control #2
There are several things you need to do to check for proper operation of the throttle lever.
First I would loosen the screw that holds the throttle cable outer jacket at the carb. You should have the air filter removed for this so you can see what is happening.
Move the throttle lever (on the dash) all the way up so that it should be in the choke position. Now, at the carb, move the throttle cable outer jacket so that the choke is closed. Now hold the jacket in this location while you tighten the clamp screw.
Now you can move the throttle lever to the idle position and observe that the choke is open and that the throttle cable operates the governor/throttle levers.
Just one more thing about the LX178. The throttle cable, in most cases, rest against the battery. On the LX178 that I worked on, the fumes from the battery corroded thru the outer jacket on the cable. This made the throttle operation very hap-hazard as it did not move the throttle in accordance with the lever.
Thanks for the help. Got it done and it runs great now.
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7731 Miles (A63689)
2019 Cadillac XTS...
TEST YOUR BID BUTTON! (A64277)
TEST YOUR BID...
2001 Ford F-550 (A66408)
2001 Ford F-550...
2022 DEMCO KARKADDY X 9713093 CAR DOLLY (A64277)
2022 DEMCO...
USA KB057-48" HYD BRUSH CUTTER (A65053)
USA KB057-48" HYD...
Livestock Head Gate (A65579)
Livestock Head...
