Lumber Mill
/ Lumber Mill #1
Egon
Epic Contributor
Nova Scotia, Canada
Finally, after several years, a simple lumber mill has been cobbled together. It may not look like much but has proven workable on the few logs it's had to square up.:D :D
/ Lumber Mill #2
Reminds me of Logosol. Just a question: the blade cuts sticking up in the air like this? How do you manage to push the chainsaw head, is there a handle for it?
I run small log mill from baileys with my chainsaw, works for my needs.
/ Lumber Mill
In the first picture the blade is set for "High Logs".:D :D
In this picture it may be a little easier to see how it works. The saw swivels and spacers can be added or removed to make different width boards.
The saw is moved using the handle.
/ Lumber Mill #4
Mornin Egon,
Nice simple setup ! :) I helped my neighbor setup the attached sawmill making various missing parts etc, its an old Lane and we had a ball getting it running. The Farmall C in the pis didnt have the guts to run it very well so we created a friction drive with an old tire and rim and hooked it up to a bigger tractor !
The white oak kitchen extension table that I built last winter had some of its lumber sawed on this sawmill ! ;)
BTW I see you have your planer setup right next to the mill, big production there !
/ Lumber Mill #5
Very ingenious, Im sure there will be alot of views and people thinking about how they canbuild one. I know a guy who made using an aluminum extension latter as base. He said it worked 'OK" but went on to build one using a band saw blade.
Quite amazing how he made that one, even so , that he bolted it together, No welding to the metal frame at all.
nice job
Al
/ Lumber Mill
It's been a long time since I've seen a belt hooked up to a tractor Scotty!:D :D
/ Lumber Mill #7
OK, I looked at it early in the morning - and the second picture helped too.
I have two maples awaiting milliing currently, but waiting for the weather to cool down a bit.
There is an active milling group on Yahoo with lot of pictures and some of the setups are just amazing.
/ Lumber Mill #8
Morning Egon.
Pretty niffy idea...maybe some actions pics???
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
2019 FORD F-550 SUPER DUTY (A65643)
2019 FORD F-550...
7'x12' Trailer (A64127)
7'x12' Trailer...
1995 Peterbilt 379 Tri-Axle Dump Truck (A61573)
1995 Peterbilt 379...
18' Dovetail Trailer (A64127)
18' Dovetail...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
