LD1
Epic Contributor
On my never ending quest for more info about building my upcoming pole barn.
One of my concerns is the trusses. The only company that has gotten back to me so far on 8' OC trusses for 40' span is quoting 2x6 lumber for both top and bottom cords. They are quoting 2400-2.0e msr lumber though. However, it still seems a bit light to me. A similar building built by Morton that I looked at had 45' span trusses with a big 2x10 top and a 2x6 + 2x4 for the bottom.
I know the new "thing" seems to be MSR or MEL lumber as to know exactly what you are getting so you don't have to "over-build". But I am not sure I am sold on it.
So I was doing some research on lumber....considering building trusses (which I probably won't). Using the span calculator at Maximum Span Calculator for Joists & Rafters shows #2 SPF being able to span farther than #2 syp. I always thought grade for grade syp was stronger.
Now for #1 and select structural, syp is better, but not in #2?
Also seems syp isn't just #1, #2, #3 anymore. There is dense, and non dense, and selections for prior to 6-1-13, and selections for after 6-1-13??? And the grading prior to that date is stronger.
So what happened June of last year?
In the 18-22' lengths that I am looking, Menards, Lowes, etc only have #2 syp or #2 SPF for choices. And given the current span ratings for that commonly available lumber, SPF is stronger? Just don't seem right.
And using the current span tables, a simple SPF #2 2x8 will span farther for a given distance than the 2x6 2400 msr lumber the truss mfg was quoting. So why not use the 2x8 that is a little stronger vs the more expensive msr 2x6??
Anyone shed any light on the topic?
