Lubrication - valve levers
   / Lubrication - valve levers #1
PointyHairedBoss
Bronze Member
Orrville, Ontario
Kubota B21 TLB, Kubota B2920
What lube do you use for hydraulic control valve levers?
I was thinking white lithium.
  • 1.pdf
   / Lubrication - valve levers #2
Silicone Spray Lubricant, Aerosol Can. Mostly invisible so it doesn't look as if it is accomplishing much but it is.
   / Lubrication - valve levers #3
I've used white lithium, 30 weight oil, JD SuperLube and I'm sure the Silicone Spray Lubricant would work too.
I suspect it's more import that you keep it lubricated than what you use.
Did your levelers for the backhoe every get freed up?
Pete
   / Lubrication - valve levers #4
Fluid Film for me.:thumbsup: Use it on just about everything.
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
2010 KMC 3376 Peanut Combine (A53473)
2010 KMC 3376...
2011 DODGE CARAVAN (INOPERABLE) (A53843)
2011 DODGE CARAVAN...
2006 International 7400 Dump Truck (A47477)
2006 International...
11 SERVICE BODY BED (A53843)
11 SERVICE BODY...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
