Lubrication of the main lifting bolts
   / Lubrication of the main lifting bolts #31
I sure hope this is the end of the shim story.
   / Lubrication of the main lifting bolts #32
"" I wonder if 14 is leaving them loose ""
I make the bolts 'snug tight'. Tight enough to prevent the bolt from rotating or loosening, but not so tight as to bend in the ears of the mount.
I do not use shims. The arm will rotate at whichever connection has the least friction. I would rather replace my bolts someday than my balls!! But, with both free to move, that prospect is very unlikely!
PS: Glad you folks like my mixture!!
/forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Ok 14 looks like I'm in line with your thinking. One other thing. If one greases the main joints with a grease gun then I am thanking that only the bolt gets lubricated. Thus I will spray the ball of these joints as well.
   / Lubrication of the main lifting bolts #34
"" only the bolt gets lubricated ""
After removing the bolt, spread grease inside the hole with your tool. Coat the bolt with grease, and reinstall.
Periodically, and after each washing, paint your balls with 14's Mixture!
   / Lubrication of the main lifting bolts #35
all attachment points,have to be welded ,if the are not welded in perfect alignment,and the wear from use.these joints makeup for this condition.most large equipment have went to this system long ago.
where are you guys getting super lube now? i use to get it at lowes, but they don't have it any more.
   / Lubrication of the main lifting bolts #36
walmart has it ...or had it been a couple of month since i got mine there and by the way i also talked to terry at pt and he told me the same as someone else here about the shimming not needed and to use superlube so i think i may try 14s mixture and remove the shims and just tighten the bolts so they dont move and left the movement happen where it will after i lube the bolt with some grease and the ball joint with the super 14 mixture /forums/images/graemlins/wink.gif
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
SHOP BUILT FLARE STACK (A53843)
SHOP BUILT FLARE...
2013 International DuraStar 4300 Altec L42A 42FT Bucket Truck (A55852)
2013 International...
2015 TROXEL 130BBL KILL TRAILER (A53843)
2015 TROXEL 130BBL...
GROUNDHOG ZH12G EXCAVATOR (A57192)
GROUNDHOG ZH12G...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A53422)
2012 Chevrolet...
