Lubricating questions on TC 30 New Holland
   / Lubricating questions on TC 30 New Holland #1
diamond dave
new holland
I am helping a woman who owns a NH TC 30 to maintain her tractor.
How many quarts of oil does a TC 30 require with an oil change and filter? Also where is the oil filter located?:)
Diamond Dave
   / Lubricating questions on TC 30 New Holland #2
This TC-Series link should get you started. It does not give fluid capacities but my 33D needs 1gl for an oil change.
Larry Thanks for the info.
DD
   / Lubricating questions on TC 30 New Holland #4
You might want to check my following advice but I did read this somewhere on TBN. When adding oil to a TC series tractor, add the oil slowly. Why? If the oil puddles on top of the cylinder head it will run down the positive crankcase ventilation (PCV) hose into the intake manifold. When the tractor is cranked, the oil will be pulled into the cylinder thus causing a hydraulic lock resulting in a bent piston connecting rod.
Two years ago a person asked me why his engine was knocking after changing the oil. He also said it was like the battery was dead but did finally start and began knocking and misfiring on one cylinder. At that time I did not know the answer.
   / Lubricating questions on TC 30 New Holland #5
I also recall that sad tale. I expect adding a quart then waiting 10 seconds or so and adding the next if fine, I don't know for sure. Also, I think this is only true on some models, but I don't know which ones.
2021 Harley-Davidson FLHP Police Electra Glide Motorcycle (A51694)
2021...
2016 Ford F-450 12FT Flatbed Truck (A51692)
2016 Ford F-450...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2017 JOHN DEERE 350G LC EXCAVATOR (A52705)
2017 JOHN DEERE...
Altec AM55 55ft Electrically Insulated Material Handling Bucket Truck Body (A51692)
Altec AM55 55ft...
2017 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A54607)
2017 FREIGHTLINER...
