Lt1042
/ Lt1042 #1
studm1
Can someone give me a replacement oil filter number for
a KH-25-050-25-S e.g. Fram etc.
/ Lt1042 #2
Be careful oil filters are not all the same. I would stick with a Kohler oil filter
on a Kohler engine.
Cub Cadet filter KH-25-050-25-S
You can use 2 Kohler filters
12-050-01-S
Or
52-050-02-S
I recommend NOT Using a will fit after market filter that say Kohler Replacement filter.
Use OEM Parts when ever possible on these engines.
Spend the $8 or 9$ on original than risk an engine with a $4.00 filter
You already have a $1600.00 investment. Protect it !!
Just my Opinion
Kevin Emerich
/ Lt1042 #3
on a Kohler engine.
12-050-01-S
Or
52-050-02-S
Just my Opinion
Kevin Emerich
I agree. LEAVE FRAM on the shelf, worthless POS they are. Take care of your local dealer, IMHO.
/ Lt1042 #4
To each his own I guess. I've been using Fram filters since 1978. I used Fram for both engine (Kohler) and transmission on my 1450, which ran 1200 hours from 1978 to 2004. I've been using Fram for the Kohler engine on my $7k 3235 from 2004 to present with no problems on either. I had to pull the 1450 engine and replace the oil pan and the engine was spotless inside.
Bob B.
/ Lt1042 #5
Patronizing your local dealers is a great thing, but obviously there is no need to run OEM oil filters. Not sure what engine/series you have on your 1042, but I run the equivalent to a Motorcraft FL400 on my Kohler Command 20hp. It's about twice as long as the OEM size filter (engine holds more oil with it). There are probably a dozen aftermarket filters 'sizes' that are completely compatible with your Kohler. I don't use Fram anymore because of their cost, when I can get a Carquest/Napa WIX, etc...etc.. for the same price. Many OEM filters are made by Honeywell and are identical to a store-bought Fram, but painted other than orange. Filter bypass settings have nothing to do with actual through-put through a filter. Bypass settings are specific to the filtering media.
Joel
/ Lt1042 #6
I don`t know for sure about the cingle cylnder kohler,but my v-twin in my 1045se takes an A/C pf-52 filter,or Fram ph-3600.
/ Lt1042 #7
lexus114 said:
I don`t know for sure about the cingle cylnder kohler,but my v-twin in my 1045le takes an A/C pf-52 filter.
Im sorry,my filter numbers were wrong,its an A/C PF 53 oil filter
/ Lt1042 #8
It is my opinion that the $8.00 and $9.00 filters are really $4.00 filters in disquise.
/ Lt1042 #9
Oil filter cross-reference for a CC LT1042 with a 19 HP 1 cyl Kohler Courage Engine:
"Briggs/Kohler type" 3/4" X 16 threads 8-11 PSI Bypass
Gasket 2.734"OD 2.430"ID 0.226" thick
Length" Wix Purolator Hastings Kohler B&S Baldwin JD TEC MotorCraft AC Fram
2.3" 57035 NA LF503 2805001 492932 B7165 ? 36563 NA NA? NA
2.7" 51056 L35310 LF302 1205001 492056 B1410 AM125424 36262 NA PF2210 PH8172
3.4" 51348 L10241 LF157 5205002 491056 BT223 AM101207 ? FL793 PF53 PH3614
Choose a filter length based on what you have for clearance when the filter is mounted....
/ Lt1042 #10
Similar to the Drive System Fluid. An inexpensive product with an expensive Cub Cadet label.
That doesn't make either of them bad though, just overpriced...
Wolverine Quick Attach Trencher (A66408)
Wolverine Quick...
2001 International 4000 DT 466E (A60462)
2001 International...
Farm King 300 bu Gravity Wagon (A66408)
Farm King 300 bu...
New/Unused Landhonor Tree/Post Puller (A65583)
New/Unused...
2013 Komatsu PC360 Excavator (A60352)
2013 Komatsu PC360...
2018 New Holland C227 Compact Track Loader (A63689)
2018 New Holland...
