LS240 3.9hrs F11 1221 error
   / LS240 3.9hrs F11 1221 error #1
JCoastie
Platinum Member
Coastal AL
LS MT240HE
It cleared after a restart, but dealer says they can't diagnose without putting it on a scanner.
   / LS240 3.9hrs F11 1221 error #2
I read that one user had the same issue and it was fixed with a software patch. Let us know how things go. I have a 240HE on order.
   / LS240 3.9hrs F11 1221 error #3
thanks for that, I wish they would have made sure everything was updated before delivery.
   / LS240 3.9hrs F11 1221 error #5
I just had the same code, and it turned out to be the hand throttle lever. Either way you would need to have the dealer's computer to plug it into to diagnose it properly. Luckily, you're still under warranty.
the dealer came out, cleared the error, ran a regen, and that was it. We'll see what the future holds.
There were 3 ECU errors in the queue.
same error happened again today at 99 hours. Cleared with a restart, RPM was limited to 1500 during the error.
   / LS240 3.9hrs F11 1221 error #8
I had the same error on my XR4145 last fall. Turned out to be a faulty hand throttle. Dealer replaced it under warranty, and I have not had problems since.
2018 Ford F-550 Altec AT48S 47ft Bucket Truck (A55973)
2018 Ford F-550...
2012 International Prostar (A56435)
2012 International...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2013 POLAR TANK TRAILER CRUDE TRAILER (A58214)
2013 POLAR TANK...
2017 Mitsubishi Mirage G4 Sedan (A56859)
2017 Mitsubishi...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
