LS XR4150 Hydro losing RPM and hp
   / LS XR4150 Hydro losing RPM and hp
Afteroil and filter change, hydro transmission and hydrolic filter changes, new fuel filter it worked great for about 10 minutesthen this.
   / LS XR4150 Hydro losing RPM and hp #12
Was the fuel filter done at the same time? Try replacing it again and if you get the same results you'll have to drain the tank.
   / LS XR4150 Hydro losing RPM and hp #13
Does your tractor have a low pressure fuel pump that supplies fuel from the tank to the injection pump or is it gravity feed?
No,it is a high pressure system, same pump as the Dura max diesel. Its a top feed tank
Yes, all filters were changed on the same day. Been talking with the dealer too. might drop the tank in the next day or so
   / LS XR4150 Hydro losing RPM and hp #16
Only one really good reason to loose RPM and that is lack of fuel. Either fuel filter stopped up, fuel pump bad or tank/line stopped up. Might be algae in the tank that is restricting the flow at times like a big sponge floating around inside that gets over the outlet and slows down the flow. A good light will show any thing in the bottom of the tank. If it had water in the tank, changing the filters would have only worked for a little while till the water stopped up the new filter.
Does your filter have a bleed valve on the bottom? If so drain some fuel off into a clear glass container and look for water in the bottom of the container. You could also just remove the filter, tip it and drain off any liquid in it to check for water if no water drain on the filter.
My tractor is back from the dealer.
Everyone talking about the fuel system was right, kind of. The wire harness that runs to the pump was tied tightly to a bracket without extra protection and had rubbed a whole through two wires. So it would run fine until it got good and up to temp then would cut out, lowering the fuel flow.
   / LS XR4150 Hydro losing RPM and hp #18
That's good you're fixed up now.
   / LS XR4150 Hydro losing RPM and hp #19
Glad to hear it wasn't a more involved repair!
2020 Freightliner Derrick Digger Truck (A55973)
2020 Freightliner...
2016 Fiat 500X AWD Hatchback (A56859)
2016 Fiat 500X AWD...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
Deere 350G LC (A53317)
