LS XR4145H Losing power going uphill
   / LS XR4145H Losing power going uphill #31
I was getting error "ab 04", with rpms stuck at 1500. I continued to use it not sure of the solution. Eventually it started losing power too making it unusable. After reading through these forums and learning about the tier4 issues I decided to just let it idle outside by itself. After an hour or more the error was gone and I had power and control of the throttle back. I considered the egr valve, checked the grounds, everything I could find but thankfully it ended up being the simplest solution. It just needed some alone time to think about it's emissions. Been there brother!
   / LS XR4145H Losing power going uphill #32
My dealer just called and LS said it was an EGR valve and they will be shipping another one out ASAP. I am about to go look and see if it is easy to swap out so I don't have to take the thing up 2.5hrs each way.. ;)
Did the EGR valve fix your problem? I have a LS 5065 with same issue of lose of power going up hill with or without brush hog operating.
2012 International Derrick Digger (A55973)
2012 International...
2014 Ford Fusion SE Sedan (A55758)
2014 Ford Fusion...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A55315)
2023 Unverferth...
2015 Lincoln MKZ Sedan (A56859)
2015 Lincoln MKZ...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A56435)
Ditch Witch 6510A...
