LS XR4145H Losing power going uphill
   / LS XR4145H Losing power going uphill
Dealer said that LS told them originally there was an issue with some EGR valves getting paint on them and they shouldn't have been painted but that issue was supposed to be resolved. Not sure if I just got a bad one out of a batch or if it might have gotten missed on the original pull from the painted valves.
So I am now about two weeks out from putting in my new EGR valve. I spoke with my dealer he said if I wanted to do it myself he would send me a manual for me doing the labor(WIN). Took me about 35mins start to finish and was pretty easy.
I thought the tractor was powerful before I swapped the EGR valve and just had problems going uphill(last tractor was an 8N)...... This thing is a beast now with a working EGR valve!!! I can now uphill in high gear without slowing down... Love it!
Glad it was an easy fix and hopefully not too many people run in to this issue.
   / LS XR4145H Losing power going uphill #13
Glad you got it all sorted and have plenty new found power! Haven't had the issue yet with mine but good to know it's an easy fix.
I would take a look and see if your EGR valve is painted. If it is it could eventually suffer the same fate and I would push to get it replaced.
   / LS XR4145H Losing power going uphill #15
Ok so I have the same tractor and same issue of power and speed loss in high gear traveling up hill the RPM's drop way down. With your new EGR does your tractor maintain RPM's when traveling up hill from mild to steep slopes? Thanks
Unless the slope is super super steep and I'm in third gear then yep I can do it with no problems even with the pto active. :)
   / LS XR4145H Losing power going uphill #17
Good to know, I will check it out. And thanks for the heads up!
   / LS XR4145H Losing power going uphill #18
I just got my 4145 and seems to have the same problem on hills....where is the EGR valve I'll ck to see if its painted ...Thanks
On the left side under the gray cover that the hood attaches under.
   / LS XR4145H Losing power going uphill #20
Thanks for the fast reply...I'll ck that
2012 Mazada 3 Sedan (A55853)
2012 Mazada 3...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A56435)
Ditch Witch 6510A...
2021 Ford F250 (A55973)
2021 Ford F250...
2002 Isuzu NPR-HD Box Truck (A56858)
2002 Isuzu NPR-HD...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A55745)
2012 NORAM POWER...
Husqvarna 42in Riding Mower (A56859)
Husqvarna 42in...
