LS XR4046H or LS XR4040H
   / LS XR4046H or LS XR4040H #1
hitecredneck1
athens,al
kubota svl75-2
is there any real difference between these two other then 6 hp? Is it a real six hp difference or just different labels? Can the 4040 be upgraded in the future? since it's the same engine, weight etc. I also noticed these have the fuel tank down low instead of behind the seat, good or bad change?
also would you choose a http://www.grapplehoe.com/ or back hoe.
   / LS XR4046H or LS XR4040H #2
Welcome to TBN.
I have the XR3037HC (smaller model) but similar build. I have found the low fuel tank to very user friendly. Easy to access and fill. Much simpler than behind the seat and up high. Can't help you choose between the 40/46 as specs are almost identical. Looks like they boosted the fuel pump for more HP. don't know if frame is any better, stronger, or thicker made. I'm sure a few 40/46 owners will pop in with the answers you are looking for.
   / LS XR4046H or LS XR4040H #3
I have a 2013 R4041H. Tier 3. I believe the only difference is the HP rating. I think after your warranty is over you could have a mechanic turn up the fuel pump to get you the extra HP if you want it. (At least that's what we did with trucks in the old days). My fuel tank is behind the seat, not real crazy about that location, but it's not intolerable. I haven't really seen the new lower mounted tanks, I hope they are in a protected area. Can't help you on the backhoe. I only have 55 hrs on mine and I love it. It plowed snow great this winter and I plan to work it pretty hard this summer and I'm sure it will take it. Good luck, and ask away.
   / LS XR4046H or LS XR4040H #4
I thought I had heard that the 47 also uses larger injectors ... ?
   / LS XR4046H or LS XR4040H #6
I have the xr4046hc and I like where the fuel tank is. It is real easy to fill. Mine is a tier 4 tractor and haven't had any problems. I couldn't compare it to the 4040 as I don't have one of each. :)
   / LS XR4046H or LS XR4040H #7
I would be interested to see if one of those lower tanks could be adapted to an older model. I really think I would like a lower one.
   / LS XR4046H or LS XR4040H #8
I could take some close up pictures and measurements if that would help.
   / LS XR4046H or LS XR4040H #10
Me too! Then I would have a nice place for a tool box.:D
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
JOHN DEERE 6615 TRACTOR (A51406)
JOHN DEERE 6615...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
2015 Ford F-350 4x4 Cab and Chassis Truck (A55788)
2015 Ford F-350...
2014 Jeep Cherokee Latitude SUV (A53424)
2014 Jeep Cherokee...
