Price Check LS XR4046
/ LS XR4046 #1
lgardner
Trumansburg, NY
None, yet!
Dealer is offering $25,000 cash for XR 4046 with loaded tires in New York. Am I paying a fair price?
/ LS XR4046
Dealer is offing me a R4047 with 25 hours for $22,000 with FEL, weighted tires and 66" box blade. He purchased it in April because it was the last tier 3 he could get, but has decided he does not need it. It's got 22.5 hours on it. He'll do the 50 hour service and detail it for me. Drove it on his farm over the weekend, and all seems fine to me.
Dealer confirmed with factory rep the balance of the warranty will transfer to me (which I'll insist on in writing).
Seems awfully nice to avoid the tier 4 exhaust system that takes a computer to diagnose.
I know they switched engines and added the tier 4 exhaust, but what other differences, both pro and con should I be aware of?
/ LS XR4046 #4
The price on that R4047 sounds good. I'd jump all over that. I'm still leery of Tier 4, and the Tier 3 R4047 has proven to be a really good, dependable tractor.
/ LS XR4046 #6
I think both are pretty fair prices...maybe a touch high on the 4046. I paid $21,500 for my R4047, but no box blade, or loaded tires (granted, it was brand new). I'd jump on the 4047 between those two. The only two drawbacks are limited foot room when mounting, and a bit lower max lift height on the FEL than most of the competition.
/ LS XR4046 #7
Sorry for being such a noob! Both tractors are Hydro.
Nothing to be sorry about. But thanks for letting us know. :cool: I am pretty sure that you would be happy with either unit. Take a long hard look at both, which is nice since you can literally have them side by side. That will make it much much easier for you. Forget about the cost difference, get the one that YOU prefer. ;)
/ LS XR4046
XR 4046 comes with FEL.
Dealer only had XR 4046 with shuttle on the lot. Sat in that one, and didn't feel cramped at all, and I'm a big guy 6'1" 250. Drove the R4047 on his farm. Picked up some hay and dirt with it. Didn't seem like much difference to me between the 2. Parking break and 4wd selector was maybe a little better spot on the XR, but that's all I really noticed.
Thanks for the advise guys! I'm gonna sleep on it tonight, but I think the R4047 will be my choice.
/ LS XR4046 #9
The R4047 is an excellent tractor. People confuse tier 4 with better fuel economy which isn't the case. All tier 4 is emissions, they are actually worse on fuel. You aren't missing anything with tier 3. Thats why i bought my 3240, really like tier 3.
/ LS XR4046 #10
I just picked up a used New Holland Boomer 50 which is basically an R4047 and I'm mucho impressed thus far.
/ LS XR4046 #11
That has been proven false by a number of brands....Tier IV Final machines are getting better fuel economy than Tier IV Interim machines.
Further, on some machines, it's much more than just emissions device(s). As an example, Kioti went from indirect injection to common rail injection, and they also went from naturally aspirated to turbocharged in the transition from DK to NX....both typically improve fuel economy. Kubota went from indirect injection, and Turbo on the MX5100 to Common Rail Direct Injection with Turbo on the MX5200. There are many other examples of similar changes out there. So saying it's simply emissions equipment might be misleading, and totally false in some cases.
The R4047 is actually not a Tier III machine, it's Tier IV Interim.
/ LS XR4046
Ok, what's tier 4 interim mean? I thought they were basically the same engine (different manufacture) just that the XR had the computer controlled exhaust filter.
/ LS XR4046 #13
Tier IV Interim was simply a lower standard somewhere between Tier III and Tier IV Final. There are entire sections of certain websites dedicated to illustrating the differences, but that sort of stuff makes my head hurt!
The engines in the R4047 and XR4046 are completely different. The 4047 engine is a Mitsubishi design that is 152.9cu inches and the XR has a Shibaura design that is 135.2cu inches. The 4046 has a diesel particulate filter, and some form of computer monitoring, but other than that it's not as complex as many of the competitor's similarly sized engines.
/ LS XR4046 #14
The XR4046 has:
Different joystick & position.
Different steering wheel tilt setup.
Different 4wd selector location.
Different fuel tank location (much improved imo).
Slightly different seating position (and different seat?).
CAB model offered.
Updated grill design, stickers, and dash.
Smaller engine making less HP along with tier 4 stuff.
The R4047 has:
Excellent engine.
Between the two, I felt the HST hydraulics were better on the R
If you drove the two and didn't notice much difference, go for the better engine & cheaper price.
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Giyi Auger (A62183)
Giyi Auger (A62183)
2021 Deere 204L (A62180)
2021 Deere 204L...
Case IH P170 6 Cylinder Power Unit (A62183)
Case IH P170 6...
2013 Deere 323D (A62180)
2013 Deere 323D...
