Ls XR4046 DPF Limp Mode and Diagnostic Software
   / Ls XR4046 DPF Limp Mode and Diagnostic Software #1
southerbre
NL, Canada
LS XR 4046HC
I have a 2014 LS XR4046HC that is in limp mode (max. RPM of 1800). One DPF light is flashing and the red warning light is flashing. At startup it attempts to start a regen; the regen in progress light comes on but goes out after a few seconds and the first light returns to a flashing state. Has anyone tried this software for resetting the DPF or forcing a regen?
   / Ls XR4046 DPF Limp Mode and Diagnostic Software #2
   / Ls XR4046 DPF Limp Mode and Diagnostic Software #3
I've actually wanted to plug my ODBII reader into the tractor for a while just to test before it was actually needed. Here are my results. I had 1 code stored in it, and it cleared just fine.
The code opened on the Web and would be my exact issue since I have excessive regen problems.
You might be able to reset your faults to get you out of limp (dealer) mode, and force a regen manually if your model allows that like the new ones do, by holding down the regen toggle.
   / Ls XR4046 DPF Limp Mode and Diagnostic Software #4
manual regen process video on YT, not me, just a video.
Use after you clear your codes.
   / Ls XR4046 DPF Limp Mode and Diagnostic Software #5
I owned the same tractor before I traded for the new MT 3 series. Mine exhibited the same issues at around 1100 hrs. Dealer determined it was regen burner. They installed the injector kit. $2,600.00 parts and labor. Several hundred hours later it was doing the same thing again. It was either the burner kit again or possibly the ecu. You could not force a regen or fool the ecu. Eventually it went from limp mode to shut down mode. I traded it for a MT 357. I’m not sure on any of the code readers. What you described your tractor is doing is what I experienced.
   / Ls XR4046 DPF Limp Mode and Diagnostic Software #6
After I put the ODBII scanner on it last week, I noticed how dirty the connector was, so I ordered a cap. Cleaned the connector and installed the cap today. What should be a $2 piece of plastic is really $7 and yes, I know I could use a piece of electrical tape or something lol
Hopefully the dealer doesn't lose it at some point in the future!
I might make it captive somehow.
   / Ls XR4046 DPF Limp Mode and Diagnostic Software #7
You can override the tractor by putting a voltage regulator 0-12V adjustable on the fuel cutoff solenoid across the 2 black wires. This controls the throttle of the tractor. You do have to remove something from the tractor to prevent the exhaust from causing the engine to not breath properly.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2013 Ford F-450 Dump Truck (A59230)
2013 Ford F-450...
Agri-X 5' 3pt Mower (A53317)
Agri-X 5' 3pt...
Mahindra 6065PST (A53317)
Mahindra 6065PST...
Kubota L3130 (A53317)
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
