LS XJ2025H Fuse block? Where is it?
   / LS XJ2025H Fuse block? Where is it? #1
LargeTarget
LS XJ2025H
Hi,
I have a brand new 2021 LS XJ2025H tractor and was seeing if I could upgrade the work light to an LED bulb.
Of course I blew the fuse, I think.
So I looked in the manual and could not locate the fuse block :-<
I called my dealer and they looked at another tractor on their lot and couldn't find it either.
Can anyone help?
Thanks and may God bless you abundantly today.
V/R
Steve Koratsky
aka LargeTarget
I hope this helps others...
Okay, I found it and answered my own question.
I had blown the 5 amp fuse for the work light/turn signals.
It is part of the main wiring harness and is not a "block" but a group of 4 "connectors." It is right by the orange parking brake release lever.
Attached is a picture.
You have to remove the misnamed rear cover mentioned in the manual on page 5-42. It helps to disconnect the light switch cable and the ignition switch cables. You also have to remove the orange knob on the throttle to get the panel off. There is a small Philips head screw on the bottom of the throttle knob.
It should be by the battery or in an easier place to get to, but the engineers who design stuff don't seem to ever actually work on the things they design...
V/R
Steve Koratsky
aka LargeTarget
   / LS XJ2025H Fuse block? Where is it? #3
Welcome to TBN!
   / LS XJ2025H Fuse block? Where is it? #4
Thank you for this...the last 4 years I've been trying to find the fuse box ... You solved my mystery .. thanks brother
   / LS XJ2025H Fuse block? Where is it? #5
where is the fuse for the wiper motors
(APPROX 100) UNUSED FUTURE 10' GALVALUME STEEL (A51248)
(APPROX 100)...
1067 (A53342)
1067 (A53342)
2014 CATERPILLAR 289D SKID STEER (A51246)
2014 CATERPILLAR...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
2020 JOHN DEERE 7R210 LOT NUMBER 47 (A53084)
2020 JOHN DEERE...
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
