Ls xg3032
/ Ls xg3032 #1
justin86
Ls xg3032
Battery died so I changed it out. With new battery in dash will not light up checked all safety switchs that I could find. As the emergency brake seat clutch pushed in. Even the 60amp fuse along with all the other fuses. First tractor to have so any help would be nice. I bought this tractor with 136 hrs on it and it's a 2016 model.
/ Ls xg3032 #2
Start with the basics. Remove battery cables and clean insides thoroughly. Be sure battery terminals are clean as well. Inspect cables for corrosion near connectors. Replace cables on battery and tighten securely. If you can move them they ain't tight. Follow ground cable (usually negative) to frame. Clean and tighten. Assuming your new battery is good things should begin working. If they don't work confirm your new battery is a good one..
/ Ls xg3032
I sprayed contact cleaner on all connections then went over to make sure they was all tight. Then with a pen light voltage detector. Traced the hot from the battery to the starter to the alternator to the key ignition switch. Which it had power all the way through.
/ Ls xg3032 #4
If you have power all the way through shall we assume your dash lights are now working and the problem is solved?
/ Ls xg3032
Still no dash lights on. I haven't got back to messing with it yet. Just had a baby boy.
/ Ls xg3032
Now this is showing up
2016 Ford F-650 18ft Hydraulic Dovetail Hauler Truck (A61573)
2016 Ford F-650...
Case IH 4200 Combo Mulch (A66285)
Case IH 4200 Combo...
Rogator RG1300C (A63688)
Rogator RG1300C...
John Deere HX15 (A64126)
John Deere HX15...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
1986 Ford LN8000 Fertilizer Truck, CAT 3406 Engine, Ag-Ready Workhorse (A63689)
1986 Ford LN8000...
