Ls xg3032
/ Ls xg3032 #1
justin86
Ls xg3032
Battery died so I changed it out. With new battery in dash will not light up checked all safety switchs that I could find. As the emergency brake seat clutch pushed in. Even the 60amp fuse along with all the other fuses. First tractor to have so any help would be nice. I bought this tractor with 136 hrs on it and it's a 2016 model.
/ Ls xg3032 #2
Start with the basics. Remove battery cables and clean insides thoroughly. Be sure battery terminals are clean as well. Inspect cables for corrosion near connectors. Replace cables on battery and tighten securely. If you can move them they ain't tight. Follow ground cable (usually negative) to frame. Clean and tighten. Assuming your new battery is good things should begin working. If they don't work confirm your new battery is a good one..
/ Ls xg3032
I sprayed contact cleaner on all connections then went over to make sure they was all tight. Then with a pen light voltage detector. Traced the hot from the battery to the starter to the alternator to the key ignition switch. Which it had power all the way through.
/ Ls xg3032 #4
If you have power all the way through shall we assume your dash lights are now working and the problem is solved?
/ Ls xg3032
Still no dash lights on. I haven't got back to messing with it yet. Just had a baby boy.
/ Ls xg3032
Now this is showing up
2022 EZ-GO ELITE...
2 Rolls of Screen (A62613)
2 Rolls of Screen...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
Frontier Quick Attach Pallet Forks (A64126)
Frontier Quick...
1996 Chevrolet 1500 (A64127)
1996 Chevrolet...
Kubota V3600-T-E102 Diesel Engine - Pump Takeout (A63689)
Kubota...
