LS tractor supply chain issues?
/ LS tractor supply chain issues? #1
Bakercindyl
LS
Is LS having supply chain issues for parts? Our repair center said they ordered parts and it has been at least 6 MONTHS!
/ LS tractor supply chain issues? #4
what exactly did they order 6 months ago ?
/ LS tractor supply chain issues? #5
supposedly a new parts depot is being built in the US. I’ve still had back order issues with kubota / new Holland / and now titan. Would not be surprised. I keep hearing about back orders on several automotive brands as well. Fellow Cnc machine repair guys suffering from back order parts too still.
/ LS tractor supply chain issues? #6
Order your LS tractor parts from Messicks - add an "MT" in front of the part number in your search bar. I usually get the parts in 2 days an you can see if the part is in stock or not. If not in stock its another 2 days.
/ LS tractor supply chain issues? #7
As was discussed in another post, LS has moved their parts dept. into a different facility in North Carolina. The move was supposed to take a couple weeks, but ended up taking a couple months due to some difficulties. Then NC was hit with hurricanes and tornadoes. Port strikes are gonna make things worse. Almost every company I do business with has some issues getting certain things for a variety of reasons. I'd like to think they're full of crap too, but it's getting worse in this global economy and there's nothing I can do about it but be frustrated and wait, or find another supplier like Bobrown14 said. I waited for a bearing for weeks from John Deere only to be told that now they couldn't get it at all. I went to a local supplier about 7 miles away that sells bearings, seals, pulleys, belts, chain, etc. and they matched it and had it right there in stock for 1/4 the price. If it was that easy for me to get in 15 minutes , why was it not available through John Deere? Nobody could explain it to me. Weird supply chain issues. A local tractor dealer just had new tractors delivered to them with temporary steel wheels because there's a tire shortage again like when covid screwed everything up a couple years ago. I thought he was full of crap too until I saw them myself. Another local company just built a big new shop and the building has been sitting for 5 weeks with no doors on it because the builder can't get the doors because of back orders. They boarded up the new building and can't use it yet. A friend has been waiting for a month for parts for his truck and the dealer has no idea when he will get his truck back. This is getting scary.
/ LS tractor supply chain issues? #8
Kubota was the same. Some simple metric shoulder bolts. Mc master carr for the win. Being from the industrial world many seals , bearings , bushings , bolts , etc can be purchased through suppliers. Electronics are not to bad either. Arctic cat wanted $380 for my sled injectors. I searched the numbers on the injectors. They are the same Toyota carola and some Honda model injectors readily found for $18-25 a piece. Get handy with searching part and casting numbers. Jd wanted $6800 for a hydraulic pump, said it was non serviceable and whole unit sale only. We searched the casting numbers. Got the original mfg. called them up , about $1200 in parts for the swash plates , shafts , seals , bearings and good as new.
/ LS tractor supply chain issues? #9
Supposedly voices were heard at the 3:20 mark here:
Stout Utility Grapple XHD84 (A66285)
Stout Utility...
Lot of (4) Square Tube Gates (A66408)
Lot of (4) Square...
Dodge 5500 4x4 Altec Bucket Truck (A63689)
Dodge 5500 4x4...
2018 P.J. Trailer Trailer, VIN # 4P5F82023J1283348 (A65563)
2018 P.J. Trailer...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
2020 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2020 FREIGHTLINER...
