LS Tractor Oil, Gas, & Air Filter Information
   / LS Tractor Oil, Gas, & Air Filter Information #31
re: LS Tractor Oil, Gas, & Air Filter Information
I have the 4041EZ and just did my 50 hours service of ALL filters. I used all NAPA filters. I did go to my local NAPA and priced the filters after I priced them online. He couldnt even come close to the internet prices I got. My price was actually lower than what he gets them for from NAPA. I ordered mine online from fleetfilter
1) There are 3 drain plugs for the hydraulic fluid.
2) The manual says it takes 11.4 gallons of hydraulic fluid. I found that it only takes about 10.
3) Oil capacity calls for 1.9 gallons. I found that it only takes about 1.5 with filter.
As for the filters, I used all NAPA brand.
Air: (Inner) NAPA 2985 (Outer) NAPA 6438
Hydro: NAPA 1715
Fuel: NAPA 3128
Oil: NAPA 1064 (has bypass and anti drainback)
   / LS Tractor Oil, Gas, & Air Filter Information #32
Bump.
   / LS Tractor Oil, Gas, & Air Filter Information #33
Short Game,
What does "Bump" mean, i see it on several posts.
   / LS Tractor Oil, Gas, & Air Filter Information #34
Short Game,
It is just to move a relevant thread back to the front page. Giving it a "bump."
Rockinrod tried to get this pertinent info stickied to keep it up front. The question comes up repeatedly, and probably should remain on top.
   / LS Tractor Oil, Gas, & Air Filter Information #35
A little google check on that wix 51715 hydraulic filter and found a pretty good price:
Wix 51715
Not sure if this is the right one for my R4047 but I already bought one from my dealer so It'll be a while before I need to revisit this.
   / LS Tractor Oil, Gas, & Air Filter Information #36
LS S3010 Filters
Air: Wix 46438, NAPA 6438
Fuel: Wix 33262, NAPA 3262, LS part number 40056438
Hydraulic: Wix 51715, NAPA 1715, LS part number 40007638
Oil: Wix 51365, NAPA 1365, LS part number 40056451
   / LS Tractor Oil, Gas, & Air Filter Information #37
Do all of the LS tractors use the same hydraulic filter?
   / LS Tractor Oil, Gas, & Air Filter Information #38
According to my manual the valves are supposed to adjusted on the S3010 as part of the 50 hour service. Here are the instructions from the service manual if you are a DIYer:
I really like the "wrench in the sleeve" 3rd-hand trick on the second page.:laughing:
   / LS Tractor Oil, Gas, & Air Filter Information #39
LS S3010 Filters
Air: Wix 46438, NAPA 6438 (WRONG!)
JUST DISCOVERED I WAS WRONG ON THE AIR FILTER -- THIS IS THE CORRECT PART NUMBER:
Air: Wix 46449, NAPA 6449
Sorry -- see my post with pictures of both air filters
   / LS Tractor Oil, Gas, & Air Filter Information #40
So I want to verify that you guys didn't change the oil or hydro at the 50hr maintenance. The owners manual only says to change the oil and hydro filter...not the fuel filter and not the fluids. I could really save the money right now but dont want to do anything that isn't in the best interest of long-term care of the tractor. Thanks in advance for the input.
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52748)
2014 Doyle Dry...
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
