Short Game
Veteran Member
re: LS Tractor Oil, Gas, & Air Filter Information
http://www.napafilters.com/filterlookup/
I got the Napa 1334 for my R4010. I see that the 1334 has a physically larger can and a lower bypass pressure. There are some differences I don't understand and some I do. Both have the same max flow rate. I don't think I'll worry about burst pressure, as I haven't popped it yet.
A comparison of Napa 1064 and 1334:
Napa 1064:
Style: Spin-On Lube Filter
Service: Lube/Transmission
Type: Full Flow
Media: Paper
Height: 2.944
Outer Diameter Top: 3.243
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 16
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=14/30
Burst Pressure-PSI: 355
Max Flow Rate: 9-11 GPM
Nominal Micron Rating: 21
Gasket Diameters
Number - O.D. -- I.D. -- Thk.
Attached 2.475 2.173 0.233
Napa 1334
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.194
Outer Diameter Top: 3.252
By-Pass Valve Setting-PSI: 8-11
Beta Ratio: 2/20=22/40
Burst Pressure-PSI: 280
Nominal Micron Rating: 19
Gasket Diameters
Number - O.D. - I.D. - Thk.
Napa 1064:
Type: Full Flow
Media: Paper
Height: 2.944
Gasket Diameters
Napa 1334
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.194
Gasket Diameters
