LS Tractor Oil, Gas, & Air Filter Information
   / LS Tractor Oil, Gas, & Air Filter Information #1
rocknrod
Hico, TX
LS Tractor, Model R4010
Do we (who own LS tractors) need a sticky with oil, gas, air filter information?
I will add that from what I gather the following info is for the R4010:
Wix filter info:
Fuel Filter P/N 33128, Engine - Mitsubishi S4QL Engine
Oil Filter P/N 5106453, Engine - Mitsubishi S4QL Engine
Air Filter P/N 46438, Donaldson P/N P821575
WIX Filters : Filter Look-Up
Fleetguard:
Wix 46438 & Napa 6438 Air Filter: FleetFilter Secure Online Store
Napa 6438
NAPA Online
Fram Air CA9550:
Search Results
Gravely Air PP30055
Gravely 21537000 Replacement [PP30055 Grave] - $13.76 : 491588, Air Filters, Air Filters, Oil Filter for small engines
Fram Oil:
FRAM - Part Details
Also here is some info on the filter for other manufacturers models with the same engines etc. but youll have to do some cross referencing:
tractor_filters[1].pdf - File Shared from Box.net - Free Online File Storage
If you do want a Sticky - Lets contact a Moderator, like:
TractorByNet.com
Or if you know of one.
If not, so be it.
re: LS Tractor Oil, Gas, & Air Filter Information
LS Tractor – Model R4010
Engine - Mitsubishi (Diesel) S4QL Engine
Air Filter = Donaldson P/N 46438
WIX Filters : P821575
Napa: 6438
Fram: CA9550:
Gravely: PP30055
Oil Filter
Fram: PH3593A
Wix: 5106453
7.4 Quarts with new filter
SAE 15W-40
API rating SF, CD series 3
Fuel Filter
Wix: 33128
Hydraulic Filter
Wix: 51715
45.44 Quarts Conoco Tractor Hydraulic Fluid
Front Axle – 8.45 quarts SAE 90W Gear Lube or equivalent
   / LS Tractor Oil, Gas, & Air Filter Information #3
I guess I need to start looking at filters for my 7010. Where did you find the cross references for your tractor?
... Where did you find the cross references for your tractor?
looking at other manufacturer threads with the same engine, I started from there and just went crazy :)
   / LS Tractor Oil, Gas, & Air Filter Information #5
Sticky sounds like a good idea. I bought the LS service manual for my S3010 and just checked to see if they listed any references for expendables and found very little. The operator's manual mentions:
permanent type antifreeze (what is that?)
SAE 15W-40 oil
Conoco Power Train Hydraulic Fluid (brand name important here?)
multi-purpose grease for the fittings
SAE 90 Gear lube (or equivalent) in front axle
AND that's it. I'll look around the net and see what I can find.
   / LS Tractor Oil, Gas, & Air Filter Information #6
SAE 15W-40 oil
LBT, have you found any info on the filters/
If you open your air filter and look, there is a part number on the filter. There may be a two part filter in there (outer sleeve) also.
Post the number and I can find a few sources.
   / LS Tractor Oil, Gas, & Air Filter Information #8
Oil and air filter for a S3010 mitsu engine.
oil looks like S1440-02100 or S1A40-02100
air P822686
air P822686
Im seeing "31A4002100: on the Oil Filter (no dashes)
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2014 MACK PINNACLE (A52472)
2014 MACK PINNACLE...
2007 DEUTZ D 2011L03 MOTOR (A52472)
2007 DEUTZ D...
2009 CHEVROLET SILVERADO (A52472)
2009 CHEVROLET...
Heavy Duty Hydraulic 84" Broom  (A52384)
Heavy Duty...
