Ls tractor fluid reservoir question
   / Ls tractor fluid reservoir question #1
platinumaa
Hello, I have a newer tractor but it doesn't say in the manual what these reservoirs are. Someone please tell me what these are. Thank you 1463270536178.jpg1463270547979.jpg
   / Ls tractor fluid reservoir question #2
I'd assume the 2nd pic on the rear end is the hydraulic oil fill point and dip stick. The other could be engine oil fill point since I don't think it has a separate pump for power steering. Please tell us what model LS you have. The fill point pics are different than mine.
It looks like you have an R4041 based on your post from 3 years ago and the 2nd pic question was answered then.
   / Ls tractor fluid reservoir question #3
The second pic (rear) looks like the hydraulic fluid fill. On certain LS models this is where the hydraulic dip stick/fill is. Do you have hydrostat? Not sure on the other. I agree it looks like a power steering pump.
I'd assume the 2nd pic on the rear end is the hydraulic oil fill point. The other could be engine oil fill point since I don't think it has a separate pump for power steering. Please tell us what model LS you have. The fill point pics are different than mine.
I have a r4041.
I don't think it's for oil fill because on top of the engine block it says oil fill on a cap.
The copper bar just to the right is the throttle.
Thanks for the help
   / Ls tractor fluid reservoir question #5
What model year?
I think 2011
   / Ls tractor fluid reservoir question #7
On my 2016 4155HC the first picture is the oil fill. That's the oil pump, not a power steering pump. I had to look in the manual because it looked like power steering to me too.
The second pic is the hydraulic/transmission/gear fill port. My casting looks just like that.
   / Ls tractor fluid reservoir question #8
On my 2016 4155HC the first picture is the oil fill. That's the oil pump, not a power steering pump. I had to look in the manual because it looked like power steering to me too. The power steering pump is on the other side of the motor with the hydraulic pump.
   / Ls tractor fluid reservoir question #10
Seems strange that the first image would show an oil fill concept. My LS G3033h has an oil cap at the top of the engine. This is were I refill or add oil. My machine also has a pump with a plug as show in image one.
Can anyone explain this?
Thanks
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
23018 (A55758)
23018 (A55758)
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A57192)
UNUSED INDUSTRIAS...
2013 Ford F-450 Dump Truck (A55852)
2013 Ford F-450...
2022 Polaris Ranger Utility Cart (A55787)
2022 Polaris...
UNUSED FUTURE XKH39 39" HYD 4N1 BUCKET (A57193)
UNUSED FUTURE...
