Ls tractor and log sitter
/ Ls tractor and log sitter #1
Lee Majors
Midland nc
Ls 3033H & Bobcat CT235
I'd like to buy a log sitter that runs off the hydraulics of my tractor. I have a new LS mt125. I don't have a front end loader on my tractor but I do have the hydraulic hookups. Can I use the loader connections to run the log splitter ? I do not have the option for rear remote hydraulics.
/ Ls tractor and log sitter #2
You could but it’ll be slower than molasses.
/ Ls tractor and log sitter #3
Get a pump that runs off the rear pto....
/ Ls tractor and log sitter #4
You are thinking like many owners of a new machine..... what all can I get it to do.
Now think of the maintenance costs and eventually replacement cost of the tractor because it wont last forever.
You are asking a machine worth thousands of $ to do the job a $250 Chinese gas engine can do and do much faster and easier than the tractor could.
A two stage pump is the hidden secret that the gas engine splitter has over your tractor's hydraulics.
Dave M7040
/ Ls tractor and log sitter #5
Tractordata shows hyd output of KS MT125 at 4.6 GPM which should be enough to operate a log splitter. Choose 1 loader circuit & after splitter hoses are attached to tractor bungee cord lever on tractor in correct position to hydraulically power splitter hyd's. It won't operate splitter as fast as a engine operated dual stage hyd pump but it will help keep you warm.
/ Ls tractor and log sitter #6
I only sit on logs after they're made into benches. My log sitter is well cushioned too. Need to get back into working the padding off of it.
Buy a stand alone splitter.
Curious though, why no loader? Also, is the power beyond hose there for the backhoe? Not sure if they put it on without the BH.
/ Ls tractor and log sitter #7
My MF has about 6.5 GPM and no power beyond for items like a splitter, in all the inquiries I have made about adding power beyond for a splitter I keep getting replies "its going to be really slow".... And realistically Its about as expensive to build/buy a hydraulic splitter for tractor is it is for a standalone.... The proof for me was I just picked up a old DUERR 20 ton splitter and replaced bad motor and all hoses and new wheels and tires and I am into it less than the cost of PB splitter for tractor, and the there is the added cost of plumbing out the hydraulics (PB) on tractor to run splitter...
Dale
/ Ls tractor and log sitter #8
Power beyond is a fitting that is part of a hyd valve. Rear remotes is what you need to run anything off the back.
/ Ls tractor and log sitter #9
I didn't know you could buy a log sitter....
/ Ls tractor and log sitter #10
I have a Speeco 3 point log splitter that is now its 2nd tractor. The current tractor is a NH TC21D, with a little less than 5 GPM. Yes it is slow. But it works fine since I split and stack at the same time. I find I handle the wood less, the speed of the splitter works the way I am doing it. And I have one less engine to maintain and feed.
/ Ls tractor and log sitter #11
For occasional use, tying up your tractor to split wood slowly might be OK.
Seems silly to me to run a tractor when a small gas engine on a dedicated splitter will do the job faster.
If you are OK with slow, and do not split a lot, look at an electric unit if you can get the rounds near an outlet. No gas or oil issues to deal with.
/ Ls tractor and log sitter #12
i did the splitter off the tractor many years ago and i'm still a believer because of the reasons that many have already listed:
one less engine to maintain - it seems that I always have a carb that needs cleaning.
how many hours will you really add over the life of the tractor?
convenience - set the height so you aren't hunched over, drop to the ground to roll large rounds on.
sure, the downside is speed, but...
I built my splitter with an 18" stroke cylinder because my stoves are meant to burn 16" logs. I don't waste any time cycling up to the log before it starts the split and it doesn't have to retract as far.
a stand alone with a two speed pump is faster with no load, but i believe mine is faster when it is in the wood.
I don't have any help most of the time, so by the time i finish the split, kick the handle into retract, put the split piece where it needs to go, and grab the next piece to split, it's already waiting for me.
I had a power beyond set up on my tractor already, so it was simple to do, as opposed to a bungee on a valve, but whatever works.
I found that on my old tractor (JD770) i had to run around 2000 rpm to get a reasonable flow out of the 5.6gpm implement pump. you may need to run faster to get the power & cycle time you need if you are on a 4.6gpm.
/ Ls tractor and log sitter #13
I have a 3 point splitter and really like it but I don't know if it's the best choice for you. I have rear remotes. Using the loader connections would be awkward for me and require really long lines. I also have a two way splitter which makes the speed OK. I would not be happy with a one way splitter that I had to have a return cycle for because of my limited gpm. Two way splitters seem to be rare these days.
/ Ls tractor and log sitter #14
I agree with everything you mention and I do the exact same thing.
I have 8.9 gpm at 2600 rpms, but I only run the engine anywhere from 1200 to 1500 rpms, which puts me around 5.15 gpm. I just hold the remote lever with a piece of wire and it's good to go.
For the occasional use, this is plenty good for me. I also only have a 3.5" bore cylinder, then again, good enough for my needs. Not to fast, not too slow. Just right as I'm not in a race anyway.
Having a dedicated engine for the log splitter, it's just another one to maintain plus the gasoline is very expensive here (7.20 US$ / gal) versus diesel ( 4.96 US$ / gal). I only run gasoline for the chainsaw and the lawn mower really.
If I was splitting wood in high volumes to sell, I would definitely come up with something a little faster, but just for the homeowner, this setup is plenty good.
Wolverine Quick Attach Tiller (A66285)
Wolverine Quick...
1970 Freehauf Lowboy, 20' Deck with 3' Dovetail (A62679)
1970 Freehauf...
2016 Etnyre Falcon Live Bottom Trailer (A62613)
2016 Etnyre Falcon...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A65053)
KNOW BEFORE YOU...
2014 UTILITY 53X102 DRY VAN TRAILER (A59914)
2014 UTILITY...
1500 gal Poly Tank (A66408)
1500 gal Poly Tank...
