LS MT573CPS - Manure Spreader Size
/ LS MT573CPS - Manure Spreader Size #1
Damon Steinke
LS MT573CPS
Hello,
I am looking to pickup a manure spreader that will be a good size for my tractor.
I have about 40 acres i'd like to spread manure on in the fall and i have no idea what size new holland or john deere spreader would be a good fit.
Do anybody have recommendations?
I see things like this out there but don't know if its too small or too big etc.
Thanks,
Damon.
/ LS MT573CPS - Manure Spreader Size #2
How much and what type if manure will
You be spreading? Will it be wet and sloppy or packed hay or straw?
We used to pull 180 bushel rear beater spreader with tractors of similar size. They had hydraulic tail gate for sloppy manure and if memory is correct either three or four selectable speeds for unloading apron so you could set speed slow for the hay and straw packed loads from loafing shed or around feed bunks.
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2020 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
2020 BOMAG BMP8500...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
296385 (A57192)
296385 (A57192)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
PALLET OF 15 4 X 8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4 X 8...
