LS MT573 vs Kioti RX7320
   / LS MT573 vs Kioti RX7320
This is where I found it.
   / LS MT573 vs Kioti RX7320 #12
It really doesn't matter to me one way or the other. I'm not here to debate the fine print in a sales brochure. Thank you for your time and input, but like I said in my original post, I'm looking for folks with real world experience with either or both of these tractors. Anyone?
   / LS MT573 vs Kioti RX7320 #14
I hope you get some "real world" responses that help you out, and that you're having a nice holiday season.
Good luck with your decision. ;)
   / LS MT573 vs Kioti RX7320 #15
I happen to have the kioti rx7230 power shuttle cab creeper, and I love the transmission. I tried the xu series power shuttle, and the kioti was a smoother transmission. My dealer sold both kioti and ls, and he recommended the kioti in this size, and the LS in the XR frame size was just as good as the kioti offerings. It was another 900 for the creeper addition. Making it 24 x 24 and I love it. I have not tested or checked out the very latest LS MT series though.
Hey Sparkee, Do you find uses for the creeper gears and if so what? The tractor that I test drove had the creeper gears and there was so little difference between the lowest creeper gear and the highest creeper gear that there may have been just 1 creeper gear!
   / LS MT573 vs Kioti RX7320 #17
Tilling hard pack clay to add lots of amendments, positioning things with forks next to house, in bed of truck, or near expensive high risk things, implement hook up, stump and tree pulling, using boom pole for engine hoist....etc. I didnt find that all the creeper gears were the same. The LS 20x20 may have more diverse gear patterns, simply due to more standard gearing built in. I dont know as much about the LS. Does that size LS accept a backhoe?
Quite honestly, I have quit looking at LS all together. The dealer was not making me feel that was the direction I should be going in. I have decided on the Kioti and feel confident in my decision. So, I'm not sure if that LS accepts a backhoe or not. I've got easy access to a mini excavator and a pretty large industrial JD backhoe at work that I can take home on the weekends or whenever I need it, so I haven't really been seeking out info on a backhoe attachment.
I will have about 20 acres of clay to deal with. I had not thought about tilling it, but I could see where that would be a slow going process. I had planned to plow it to put the cheat grass under then disk it, but I don't know much about working ground...I have yet to ever put a crop in.
You do make a strong case for the creeper gears. I only ran the tractor around the parking lot, so that is not the best place to get a feel for all the features. I'm sure in real world experience I would find plenty of uses.
   / LS MT573 vs Kioti RX7320 #19
Speed table / chart for kioti rx series with creeper gear
Thats pretty handy! That actually illustrates what I was saying pretty well...the first 10 or so gears of the creeper gear are so close together there is not a distinguishable difference between them. That sure does make for some low gearing!
Yellow Steel Diamond Plate (A55758)
Yellow Steel...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58216)
HYDRAULIC THUMB...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2325 (A58376)
2325 (A58376)
2008 BMW 535xi AWD Sedan (A56859)
2008 BMW 535xi AWD...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
