Ls mt122 loader joystick rod repair
   / Ls mt122 loader joystick rod repair #1
Midland, Nc
ls mt122tlbm
Hey so has anyone found an aftermarket repair for these joystick rods? My loader can't curl anymore and I see the rod and slider joint are worn. I can order through my dealer, but they are very far away. Amazon shows several kits as the three piece set, but they are 1/4" threads, so I'd have to modify a bit. Any help is appreciated. Thanks.
I am thinking about ordering this. 1/4" is a tick bigger so I may have to drill out the loader mount where the three bolts go through.
I've gone through their website and for the spherical end alone, they have like a dozen choices in m6x1.0. But i was not able to find the little slide shaft that it engages. Maybe I'm just struggling with their selection?
   / Ls mt122 loader joystick rod repair #5
Your dealer can drop ship part to you
   / Ls mt122 loader joystick rod repair #6
Straight pin to fit the eye and your post. I opted to convert to heim type joints and it works well so far.
LS dealer says national back order. I ended up getting that SAE kit so I'll follow up on how it goes...
OK so the sae kit was just a bit off for sizes. So I dug deeper. I think the shifter was bumped out of adjustment. I loosened the jam nut, then moved the shifter away from the steering wheel, and locked it in. Good as new. I can't believe I didn't think of trying this at first glance. Thanks for the replies yall!
50ft Fuel Line (A51573)
50ft Fuel Line...
Arksen Rollable Fuel Cell (A51573)
Arksen Rollable...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
(2) 275 Gallon of Resinator Clean/Dust Down (A51573)
(2) 275 Gallon of...
30 Yard Roll Off Container (A51573)
30 Yard Roll Off...
New/Unused 2025 CFG MX20R Mini Excavator (A51573)
New/Unused 2025...
