Ls mt122 loader joystick rod repair
   / Ls mt122 loader joystick rod repair #1
Midland, Nc
ls mt122tlbm
Hey so has anyone found an aftermarket repair for these joystick rods? My loader can't curl anymore and I see the rod and slider joint are worn. I can order through my dealer, but they are very far away. Amazon shows several kits as the three piece set, but they are 1/4" threads, so I'd have to modify a bit. Any help is appreciated. Thanks.
I am thinking about ordering this. 1/4" is a tick bigger so I may have to drill out the loader mount where the three bolts go through.
I've gone through their website and for the spherical end alone, they have like a dozen choices in m6x1.0. But i was not able to find the little slide shaft that it engages. Maybe I'm just struggling with their selection?
   / Ls mt122 loader joystick rod repair #5
Your dealer can drop ship part to you
   / Ls mt122 loader joystick rod repair #6
Straight pin to fit the eye and your post. I opted to convert to heim type joints and it works well so far.
LS dealer says national back order. I ended up getting that SAE kit so I'll follow up on how it goes...
OK so the sae kit was just a bit off for sizes. So I dug deeper. I think the shifter was bumped out of adjustment. I loosened the jam nut, then moved the shifter away from the steering wheel, and locked it in. Good as new. I can't believe I didn't think of trying this at first glance. Thanks for the replies yall!
2012 PETERBILT 337 (A50854)
2012 PETERBILT 337...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
27 Challenger Boat (A50324)
27 Challenger Boat...
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
2019 Bobcat E32i Mini Excavator (A50322)
2019 Bobcat E32i...
2000 SCHWING P88 PORTABLE CONCRETE MIXER (A51243)
2000 SCHWING P88...
