LS MT 2XXX Models with LB1300 Backhoe have swivel seat problems?
   / LS MT 2XXX Models with LB1300 Backhoe have swivel seat problems? #1
Mrsig
Bushnell, Fl
LS MT225 4x4
Any one with the MT 2XXX models with LB1300 Backhoe have swivel seat problems?
This is the 2nd time the X bars broke on me. The first time I was moving wood with the grapple and the seat shifted right and would not lock down.
On Thursday I was using the Backhoe and the seat tilted forward & to the left & I had a hell of a time to get it up and rotate it so I could drive it out of the wood & back home. Now all you can see is the sky when you drive it.
Dealer said it should take about a week to get the new seat frame assemble. Can't use the tractor at all the way it is.
No I am not over weight for the seat!
   / LS MT 2XXX Models with LB1300 Backhoe have swivel seat problems? #2
That's quite frustrating, and the reason I can't stand swivel seats.
It took 13 days and the new frame the bars look bigger then the last ones.
   / LS MT 2XXX Models with LB1300 Backhoe have swivel seat problems? #4
You can't weld some reinforcing rods on
the original seat? It could be a spare???
willy
   / LS MT 2XXX Models with LB1300 Backhoe have swivel seat problems? #5
Good to see that they're trying to improve the part.
   / LS MT 2XXX Models with LB1300 Backhoe have swivel seat problems? #6
I have had a similar problem...I'm on seat #3. This time I re-welded the underside more thoroughly...it has been holding since. Unfortunately, I have to yank the seat up manually when using the backhoe...I'm waiting on a new design from LS but they are not much help on a more permanent solution.
   / LS MT 2XXX Models with LB1300 Backhoe have swivel seat problems? #7
Mine broke, too. Much more through weld on the replacement. Took 5 months to get it...
   / LS MT 2XXX Models with LB1300 Backhoe have swivel seat problems? #8
I've been waiting for a long time for a replacement as well. A long, long, time.
   / LS MT 2XXX Models with LB1300 Backhoe have swivel seat problems? #9
I love the tractor but the Customer Service is incredibly bad.
   / LS MT 2XXX Models with LB1300 Backhoe have swivel seat problems? #10
Pull it off take it to a welder and weld up the broken welds at the pivot points at least you'll be able to use it without feeling like you're going to fly off the tractor on any kind of an incline
2015 Dodge Charger Sedan (A50324)
2015 Dodge Charger...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
UNUSED CFG INDUSTRIAL SSFM81 FORESTRY DRUM MULCHER (A51244)
UNUSED CFG...
Wolverine Quick Attach Concrete Mixing Bucket (A50514)
Wolverine Quick...
AUCTION STARTS HERE @ 9AM (A51242)
AUCTION STARTS...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A52128)
Kubota 24in Quick...
