LS Frame Issue Video
/ LS Frame Issue Video #131
Nice tractor! I really enjoy the heck out of mine.
My dealer called yesterday and said he talked to the factory rep about upgrading my loader brackets. The rep said that they are only upgrading tractors within a certain serial number range and that my tractor did not fall within that range. Seems odd since it looks like later models of the R3039 got the upgraded brackets. Not sure if I should press the question or let it go and see what happens.
I haven't gotten mine yet, but they are supposedly on the way. I bought mine in 2012.
/ LS Frame Issue Video #132
Just to update, i went by the dealer to pick up my bracket kit for my tractor today. It just happened that the LS rep was there, as well. The dealer that ordered my brackets is a new dealer, and is only about 1 1/2 miles from me. Unfortunately they said they werent yet equipped to do this type of repair, (no welding capability). The rep told me to take it to the dealer that I bought it from, and they could handle the repair. He even called the selling delaer while I was there, and told them to take care of it, and send the claim to LS. No charge for the retrofit kit, or the labor! The only drawback is that the selling dealer is about sixty miles away. So off I went with parts, now just to get it to the other dealer! Oddly enough, the rep said they'd had more issues with the 4041/4047s than the 3039s?
/ LS Frame Issue Video #133
Great rep. Good for LS
/ LS Frame Issue Video #134
Great that you are getting the problem handled proactively, but find it hard to believe the beefier 4041/4047 frame had more problems. Did he elaborate?
Tom
/ LS Frame Issue Video #135
Interesting ... I haven't heard of a single issue regarding the R40XX tractors ... ?
/ LS Frame Issue Video #136
Tom
I was suprised when he told me that, as well, with the 41/47's having a heavier frame. He mentioned that my dealer was familiar with the repair, as they have done two. I talked with my dealer this morning about getting it in to take care of this, and found out the couple they did were indeed the larger frames! That's the first time I've ever heard of it on those machines, as well.
/ LS Frame Issue Video #137
My dealer ordered my frame kit. He said there's a service bulletin on it. Parts and labor free.
Eugene
/ LS Frame Issue Video #138
Eugene
/ LS Frame Issue Video #139
I have a 2011 LS tractor i3030 and having the same issue. The first sign of a problem was when my engine fan blades were rubbing on the fan shroud. This would happen only when I lifted a load with the front loader bucket. I then did some investigating and found a upward crack from where the cross member is welded. I dont over work my tractor and use it to clean out wood shavings from horse stalls and occasional rocks and dirt. Seems like a design flaw to have a crack with only 220hrs on it. I called my dealer and he is going to call LS tomorrow to see if there is a reinforcement kit available for this tractor.
/ LS Frame Issue Video #140
I have a 2011 LS i3030 with a cracked subframe also. It all started with a load noise when my fan was rubbing the fan shroud. It only did this when picking up a load with the bucket. Then I noticed the crack right above the cross member weld. I called my dealer and he is going to call LS tomorrow to see if theres a reinforcement kit available for my tractor. It only has 220hrs on it and I use it to clean out horse stalls and chicken pens. Seems like a weak design which causes this to crack.
2014 FORREST RIVER SALEM TRAVEL TRAILER (A60736)
2014 FORREST RIVER...
2006 TAKEUCHI TB135 EXCAVATOR (A62129)
2006 TAKEUCHI...
2014 Ford Explorer AWD SUV (A59231)
2014 Ford Explorer...
2012 CATERPILLAR 308D CR EXCAVATOR (A59823)
2012 CATERPILLAR...
2016 Texas Trailers 26ft 5 Ton T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 Texas...
Kubota RTV X900 (A53317)
Kubota RTV X900...
