Ls engine issue?
/ Ls engine issue? #103
Brits have Lorries, I don't know about the rest of the continent.
We have trucks in Europe. Like a Scania R730, V8, 730HP, awesome sound with a straight pipe. Volvo, DAF, Mercedes, MAN, etc.
We all know that the Brits have to be special... :D
/ Ls engine issue? #104
So what I have gathered from this it is only the turbo engine that has the issue?
I have the same engine just N/A so I don't think this is an issue for me. I will be doing my first oil change at 30 hours instead of 50 hours now that you guys have scared the crap out of me with the factory oil. I will look to see the Manufacturing date when I get home to which oil it is coming from at the factory.
/ Ls engine issue? #105
so should we be using 0w40 or 5w40 in these engines.i read the bulletin and seen both mentioned.im in arkansas and i use rotella t6 5w40 synthetic in mine.im at 135 hours and no problems at all
/ Ls engine issue? #106
The manual for my XR4155HC gives specifics for oil for min / max temperature ranges. Check your maintenance section.
2004 Ford E-450 Jayco Escapade 28G Class C Motorhome (A61569)
2004 Ford E-450...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
AGT Industrial ExRC54 (A60463)
AGT Industrial...
Spreader Attachment (A56859)
Spreader...
2009 Kubota M108S (A60462)
2009 Kubota M108S...
