LS blue paint
/ LS blue paint #1
JLwoodworks
Macedon,New York
LS XR3135HC
Picked up some factory color touch up paint at my dealer. $13. Not cheap, but not terrible depending on the scale of the project.
Jay
/ LS blue paint #2
One of the projects I have planned for next year is to build a tool rack / ballast rack for the 3ph. Still debating whether or not it would just be easier to spend the money for a few rattle cans, or get the Sherwin-Williams LS paint mentioned in another post. With more paint, though, I might be tempted to repaint the other implements, too.
/ LS blue paint #3
Just be sure to ask the price before buying. I've seen the same paint advertised at $33. per can at certain dealers.
I'd go for the Sherwin-Williams paint first if an exact match is wanted.
/ LS blue paint
I haven't seen the Sherwin color in person yet, but it looks to be closer than sail blue rustoleum.
I tend to paint the attachments I build black. That way they're universal.
/ LS blue paint #5
For those that haven't seen it here's the Sherwin-Williams paint code posted by other LS owners. The paint formulas may be slightly different as both were obtained by different members.
/ LS blue paint #6
The second picture of the S-W can is mine. It's a perfect match for LS Blue.
Repainted my grill guard after modifying it.
/ LS blue paint #9
Hutchman, I made a bracket to mount an ammo can on the back
I was thinking of doing the same thing, but making it with holes to hold lynch pins ... not only to hold them while putting on or taking off implements, but as a place to look and reassure myself that I didn't forget one. :confused2:
/ LS blue paint #10
That spot might work. I no longer have the work light there so I could re-purpose the threaded holes in that area for a bracket. Thanks for the idea!
/ LS blue paint #11
Just curious, how have these paints lasted over time?
If SW can make a rattle can for me that'd be great. I recently had to weld up some stress cracks on all the sheet metal and now have gray primer spots on everything. Unfortunately my tractor sits in the sun more than it should, so what was once blue is now powder blue.
/ LS blue paint #12
SW will give you the paint & any additives for conditions, but doubt you'll get it in a rattle can. Best bet would be paint etc. from them and a cheap HF or Amazon hvlp gun that you can hook up to your compressor. Don't forget filters for both air and paint. Dry, oil free air.
/ LS blue paint #15
I used safety blue on my grill guard, it's not close, not even the same sport!
I did contact my dealer, and they do have touch up paint available, I didn't get a cost though.
/ LS blue paint #16
Safety Blue Rust-Oleum is a perfect match to my eyes......
I repainted the front bumper with the Rustoleum Safety blue and I can not see any difference in the color on a bright sunny day.
/ LS blue paint #18
Yeah, used Safety blue on a couple of deep scratches on the 'flat' parts..... can't even see where the spray 'patches' are.
There is a common mistake to use Rustoleum "sail blue"..... that is definitely darker and not a match.
I have a can of LS touch up paint from the dealer..... I will use it as a last resort. It takes over 24 hours to dry, vs. the Rustoleum is dry in 20 minutes.
There have been a couple touch ups, using the Rustoleum, for about 2 years now. They are holding up just as good as when first applied.
